Old 06-16-2011, 11:52 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Borgeson Steering Shaft?
Anybody have one? Input? Thanks, Bradley
LINK: http://www.borgeson.com/xcart/produc...productid=1449
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-16-2011, 11:58 PM   #2
85burb
85burb's Avatar
Re: Borgeson Steering Shaft?
Dont have on but want one. It looks like a smaller one that come on big petes. They last long time if you grease the u-joints properly.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 06-17-2011, 09:42 AM   #3
Burt4x4
Burt4x4's Avatar
I bought peices not the premade one (first gen spline count is different) but it is Borgeson and it works awesome
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 06-17-2011, 10:20 AM   #4
AJs72K5
AJs72K5's Avatar
I don't suppose you still have part #s Burt?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 06-17-2011, 03:53 PM   #5
OrrieG
OrrieG's Avatar
Nope, I made mine using an Astro Van and stock 74 shaft, cut, flipped to work. $10 at the wrecking yard, plus a couple of set screws. Not as sleek as Borgeson but it's not a show car.
Old 06-17-2011, 05:02 PM   #6
Burt4x4
Burt4x4's Avatar
I do
I happen to be working from home today.
My first look I found the part # for the Vibration dampner u-joint.
Quik story ~ I bought the wrong one at first, painted it and tried to mount it after...they would NOT take it back cuz of the paint! BOOOoooooo, I sold it for 40 bucks.
Anyway
I bought the DD slipp shaft, cut to fit and the steering wheel end # I still need to find:
on 11/15/2004 ~
034940 = 3/4"DD & 13/16-36 spline
(I first bought 034934 = 3/4"DD & 3/4-36 spline)
It was $103.95 (back when I had lots of credit, Doooh!!)
I first bought the non-dampner version (cheeper) in the 90s. When I put the 454 in and uesd ORD engine mounts and started thinking alot more frame vibration will be present so I upgraded that part.
Old 06-17-2011, 05:45 PM   #7
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
I put one in the K5 I used to have. Good solid product. Installation is straight forward. Just be sure to paint it if you get the bare metal one.
Though I have to say that OrrieG's is a fantastic alternative.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-17-2011, 09:11 PM   #8
str8axle55
You could just go with a Jeep XJ shaft, that`s what I did. Cheap and effective, very popular swap for 4X4`s, like $20 at the Junkyard and about 20 min to install.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
Old 06-21-2011, 12:54 AM   #9
orbot
orbot's Avatar
X2^^^^
I did it, just be carefull and dont melt the plastic clips.
orbot is offline   Reply With Quote
Old 06-21-2011, 01:24 AM   #10
CrewCab59
CrewCab59's Avatar
XJ is the way to go.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 06-30-2011, 11:34 AM   #11
bigd65
bigd65's Avatar
I have one but actually a little different. Mine the swivel went on top because the bottom ( at the gear box) was still the same attachment type for the rag joint. But I really do like it
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 07-01-2011, 09:57 AM   #12
Yukon Jack
Yukon Jack's Avatar
Here's a good older thread on the Borgeson option.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
