Old 06-16-2011, 04:29 PM   #1
JimQ
JimQ's Avatar
327 PCV Grommet
Hey guys.
I need some help locating a PCV grommet for a 327. The 327 is a transplant from a '66. The grommet is located in the block back by the distributor and oil pressure switch. Any idea?
Thanks.
Q
'64 K20 327
JimQ is offline   Reply With Quote
Old 06-16-2011, 04:36 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: 327 PCV Grommet
Are you looking for an open vacuum port?
Nevermind. I miss read.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 06-16-2011, 04:46 PM   #3
JimQ
JimQ's Avatar
Re: 327 PCV Grommet
I have a setup like this... looking for the grommet shown here:
http://www.parts123.com/parts123/yb....~Z5Z5Z5~Z5Z5Z5
I searched the PN shown and found this on eBay.
http://cgi.ebay.com/ebaymotors/1963-...#ht_1324wt_939
I wonder if that would work.
Q
'64 K20 327
Old 06-16-2011, 05:06 PM   #4
blackedoutharley
Re: 327 PCV Grommet
That port is where the road draft tube is connected... pcv is usually located in the valve cover.
If your valve covers have a port use that and plug the road draft port on the block with an appropriate sized freeze plug.
The road draft tube vents crankcase pressure straight into the air.
blackedoutharley is offline   Reply With Quote
Old 06-16-2011, 05:58 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 327 PCV Grommet
The following thread shows installations with both a grommet and post #13 shows the early adapter nipple that bolted in the block hole with the same bolt that originally fastened the road draft tube:
http://www.jalopyjournal.com/forum/s...d.php?t=151629
Old 06-16-2011, 07:50 PM   #6
JimQ
JimQ's Avatar
Re: 327 PCV Grommet
Awesome link. Thanks very much!
Here is the setup I have, along with a vented cap on the oil fill tube...
I'm sure I can come up with the right combination of parts to get it done.
Thanks again.
Q
'64 K20 327
Old 06-17-2011, 04:04 PM   #7
Heater63
Heater63's Avatar
Re: 327 PCV Grommet
and try a car catalog from Classic Industries that covers 66 (not camaro, too early)
292 + TKO500
Heater63 is offline   Reply With Quote
