Old 06-18-2011, 11:35 PM   #1
mrsmothers
trans swap questions
well I am tired of three on the tree. I have a 350 in a lwb what all do I need to swap in a turbo 350 and how hard is it to put in ?
mrsmothers is offline   Reply With Quote
Old 06-18-2011, 11:52 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: trans swap questions
Nooooo leave the 3 on the tree!! new bushings/lube and adj it!!!!!!!!
John
1999 Toyota Tacoma 4x4
Old 06-18-2011, 11:58 PM   #3
Hubscrub
Cruzin
Hubscrub's Avatar
i have to agree with ^ i miss my 3 on the tree/ but to do the swap you will need a the auto trans crossmember (remove the manual one), kickdown cable, auto trans radiator or separate trans cooler, auto column or floor shifter, and maybe drive shaft altered/lengthend/shortend, flexplate, maybe more all i can think of .....
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-19-2011, 06:47 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
...plus a starter and starter bolts, trans mount, and vacuum modulator line and manifold fitting.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
