Re: '66 GMC BBW w/351E and Factory Buckets
I just put gas in it. I was hoping I didnt have to line it at that point but my tank was pretty dang bad.
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
its holding up on ya? no more rusting has ocured?
![]() Join Date: Jun 2010
After the initial muratic acid cleaning (and rinsing/drying), we put gas in and still had rust issues...no coating yet.
We then elected for the Hirsch kit and recleaned and coated the tank and are still on the first tank since then with no probs...so far. The new 10 bolt rearend is narrow at 61" WMS to WMS, but having 0 miles on it makes up for it's "short" comings... ![]() New spring pads, u-bolts, plates, and u-joints for the old driveshaft and the rearend was a bolt-in job...even the old brakelines fit with no modifications. ![]() We did pull the bottom three leaves out of the stock 9 leaf pack, dropped it a bit and seems to ride nice...we're considering cutting a portion of a coil off the front too.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
Few more pics of before and after spacers...
thanks for the info i need to do this with mine
60-66 Nut
So does that Colorado rear end have the 6 x 5.5 wheel bolt pattern?
If you have any questions when you do it feel free to ask bud!
Yes it does, a lot the guys told me that you can physically see the difference in size of bolt pattern between a full sized rear and the colorado rear. But i felt like being stubborn and trying one of my wheels onto to it, and sure enough it fit perfectly, it also fit the full sized rear.
