Closed Thread
Old 06-21-2011, 09:28 AM   #2401
NevadaDVX
Re: What did you do to your truck today!
Originally Posted by magwakeenercew2jh View Post
What color/paint is that? Very nice.
It's a late model Ford color, Cinnamon Clearcoat Metalic. Looks great in bright sunlight, but looks more brown in the shade.
NevadaDVX is offline
Old 06-21-2011, 09:49 AM   #2402
colin_havens
colin_havens's Avatar
I was going to ask what color that was, its very nice. Something about classy suttle looking colors have been appealing to me lately, instead of loud bright ones. I like it (even if it is a FORD color )
colin_havens is offline
Old 06-21-2011, 01:33 PM   #2403
LakeMtn
began cleaning the underside. Grease Lightening works good!!
LakeMtn is offline
Old 06-21-2011, 05:10 PM   #2404
Jeffs70
Jeffs70's Avatar
walked in the shop and looked at it. then walked out shaking my head at the heat LOL
Jeffs70 is offline
Old 06-22-2011, 11:47 AM   #2405
colin_havens
Spent last night working some more on tuning the engine. I pulled the carb, due to a small vaccum leak I was having, and removed the old gasket materal. Put on a sealing plate from Holley, should keep it from doing that again. Also plumbed in a PCV valve, as I had not been running one before. Pulled the HEI and sut a advance curve kit in it, and slid it back into the motor. Just have to bolt the carb back down, and set my timing again, and I should be good to go. I was tired if it running so rich and fouling plugs, and you could just smell the excess gas coming out of the tailpipes. Should get a little more get up and go, little better mpg, and no more smelly exhaust!
Old 06-22-2011, 11:51 AM   #2406
JJanzen
JJanzen's Avatar
Several weeks ago as summer was approaching, I decided to get my factory ac up and running on my 72 blue Cheyenne Super daily driver. I noticed that on one of the hoses coming off the back of the compressor, it attached to the hose fitting at the "heater box" area with just a standard hose clamp. My first thought was there was no way that it was holding pressure so i decided to remove the hose and get it rebuilt correctly. While waiting on the hose, I decided to go ahead and remove the compressor, clean it up, re-paint it. Well, you can't put a cleaned up compressor on old nasty brackets so they came off next. This exposed an old rubber fuel line from the fuel pump that had bothered me for years so I rebuilt it with a hard line as well. As I am looking at the front of the engine now partly exposed, I was reminded of the on going cam problems that have haunted this truck since I got it about 4 years ago. The previous owner had re-built the motor and made a number of errors that needed correcting including the cam selection. I decided if I was ever going to get this motor right, I needed to replace it. I selected the Comp Cams 268H based on my freind JohnO's experience. So, I pulled everything apart and re-finished it in Chevy Orange. JohnO helped me put all back together and I must say, it runs better than I could of expected. Other than the waterspots in the pictures, it also looks like it now runs!
Blue72
Red72
JJanzen is offline
Old 06-22-2011, 11:58 AM   #2407
GMC69
GMC69's Avatar
I replaced the plain side markers with deluxe side markers that I got for my birthday last night.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline
Old 06-22-2011, 12:54 PM   #2408
Dano69c10
Dano69c10's Avatar
JJanzen
That engine looks clean, I especially like the fuel line.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 06-22-2011, 02:26 PM   #2409
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Parked the '71 next to the house so I can see it every time I walk through the kitchen
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline
Old 06-22-2011, 08:10 PM   #2410
JJanzen
JJanzen's Avatar
Originally Posted by Dano69c10 View Post
JJanzen
Dano
Thanks Dano. Now I just need to replace from the fuel pump to the tank. For some reason, the PO stuck it on top of the frame!
Blue72
Red72
JJanzen is offline
Old 06-22-2011, 08:31 PM   #2411
mrbwtie
Cool Re: What did you do to your truck today!
Or is the question "what did your truck do for you today"? It took me for a ride. The temp was 97 degress outside and it had to be 180+ under the hood.I was getting vapor lock.
mrbwtie is offline
Old 06-22-2011, 08:34 PM   #2412
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Originally Posted by mrbwtie View Post
Or is the question "what did your truck do for you today"? It took me for ride. The temp was 97 degress outside and it had to 180+ under the hood.I was getting vapor lock.
Fine looking truck in your avatar, mbt. Tubbed? You have air in that sweetheart?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 06-22-2011, 09:06 PM   #2413
mrbwtie
Air, I wish. The only problem I am having is vapor lock. the tremendous amount of heat under the hood is killing me. Cool can or maybe a hood scoop?
mrbwtie is offline
Old 06-22-2011, 09:56 PM   #2414
Bennett68C10
Bennett68C10's Avatar
Beautiful truck you have there, what color orange is the paint. I love it
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 06-22-2011, 10:28 PM   #2415
67Slider
67Slider's Avatar
Went to the Pick-n-pull on my lunch today and scored a new Power Steering Box for $30. Degreased it and shot some paint on it when I got home. I will install it this weekend and see if it is gonna leak like my old one. It seems evertime I fix one leak I get two more. Blew a line on my front brake and it looks like my PS pump may be leaking now. ARGGGHH!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 06-24-2011, 01:53 AM   #2416
wwotr
wwotr's Avatar
Went and paid the Invoice, looked it over and the Wifes taking me to trhe shop to bring it home tomorrow!
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Old 06-24-2011, 09:40 AM   #2417
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice looking ride ya got there..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 06-24-2011, 02:55 PM   #2418
mmmBoost
An electric fuel pump will cure your vapor lock. put the pump as close to the tank as you can. Fuel under pressure raises the boiling point of the fuel. I put an electric fuel pump on my truck in Arizona never vapor locked again.
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 06-25-2011, 11:04 PM   #2419
kcsa75
kcsa75's Avatar
Making progress on the engine compartment. Still have a ways to go, but we're getting there.
The top photos are what I started with.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline
Old 06-26-2011, 02:18 AM   #2420
wwotr
wwotr's Avatar
Actually picked it up from the Shop after having the Exhaust Tucked up into the Frame, New Horns put on, and a new AC Relay put in.
Hello members...
RIP...."RATIKLE"
wwotr is offline
Old 06-26-2011, 07:43 AM   #2421
88fordf150
88fordf150's Avatar
Finished up putting the stars & stripes treatment on my tach.
Brad handshoe
88fordf150 is offline
Old 06-26-2011, 08:39 AM   #2422
Lippyp
English Chevy Owner
Lippyp's Avatar
That tach is cool! I finally managed to get the seized bolt out of the firewall main wiring harness plug so i can finally get on with rewiring the engine bay.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline
Old 06-26-2011, 08:41 AM   #2423
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
we need more pics of this!!!
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 06-26-2011, 09:57 AM   #2424
mdaven@aol.com
Loosened the bolts holding the seat so I can remove the water soaked carpet. Plan to clean and prime the floor prior to installing a LMC rubber mat.
mdaven@aol.com is offline
Old 06-26-2011, 02:37 PM   #2425
mightymouse
mightymouse's Avatar
worked on the bed ' all weekend . thinking about what a waste of time
mightymouse is offline
Closed Thread
