Old 06-21-2011, 06:08 PM   #1
TheApocalyptican
TheApocalyptican's Avatar
dash years?
Will the 73-80 dashpad fit on the 81-91 metal dash "skeleton", or are they completely different? From the pictures I have seen, I like the 73-80 pads better. Especially because of the strange angular passenger side on the dashpad of the 81-91's.
1995 Suburban K2500 454.....off road & towing
1999 Astro, work van
2006 Silverado 2wd 5.3 w/4.5" lift and 33s
TheApocalyptican is offline   Reply With Quote
Old 06-21-2011, 08:02 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: dash years?
Yes they will fit fine the only thing is that your vin will be hidden by the dash.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 06-21-2011, 10:38 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: dash years?
i think there is a small gap at the top
prob get a pic tommorrow......
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 06-21-2011, 10:45 PM   #4
TheApocalyptican
Re: dash years?
a picture of what you mean would be great
Old 06-21-2011, 11:41 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Re: dash years?
i got my 78 dash on my 89 burb
John
Old 06-22-2011, 12:03 AM   #6
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: dash years?
I put a 78 dash pad in my buddy's 86 K5. For the most part, it is a direct swap. Here are some things to consider:
You will need a dash bezel from a 73-80, as well as the piece that goes under the steering wheel.
If your wiper switch is on the column, there will be an empty slot where the wiper switch would be. I put a toggle switch there for the off-road lights.
The headlamp switch will be in the wrong spot on the new bezel. You'll have to drill a new hole for the switch, and move it up. Not a hard thing to do, but remember to mount the dash bezel, mark where the new headlamp location will be, and drill away.
sixshooter798 is offline   Reply With Quote
Old 06-22-2011, 07:22 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: dash years?
you don't need to change the bezel tho
except for the switches they look the same from what i've seen
what i have here is a silver 87 and a black 78
i plan to put the bezel from the 89 burb in to match everything else from it
John
Old 06-22-2011, 07:43 PM   #8
sixshooter798
Desert Rat
Re: dash years?
When I did the swap, the 86 bezel did not fit properly on the 78 dash.
