Old 03-02-2011, 10:58 PM   #1
Goats86
86 C10 with a rear axle flip what shocks??
Got some axle saddles and moved the axle on top of the leaf springs. How do you determine what shock to go with? I thought about loading the bed down till it bottoms and measure the mount to mount and then at ride height add maybe 3 " to get a range? Any ideas? Plain old Monroe's or similar, nothing high $
Goats86 is offline   Reply With Quote
Old 03-03-2011, 07:03 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 86 C10 with a rear axle flip what shocks??
I always run a set of shock extenders.
Not only do they allow you to use stock shocks with your flip kit,... they also help correct the shock angle.
If you don't have a set,... I highly recommend them.
PerformanceOnline sells them for $49.99.
(part#RSE7387)
Keith
Convert to disc brakes.
Old 06-22-2011, 11:10 PM   #3
iceship
Can u use front shocks in the rear..... so I don't have to buy one more thing.... just don't know if I'm going to do a flip or remove so leafs...
iceship is offline   Reply With Quote
Old 06-22-2011, 11:17 PM   #4
iceship
LMC's flip kit don't come with extenders.....
Old 06-23-2011, 02:23 PM   #5
SCOTI
SCOTI's Avatar
LMC sells alot of stuff that isn't necessarily the best option. Bell Tech, Western Chassis, & McGauhys I believe include them w/their kits. As Lolife mentioned, a shorter shock doesn't correct the working angle; the shock mount extender does.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
