Old 07-30-2003, 06:42 PM   #1
brad20653
Inner fender help
Is the inner fender hard to put in on a 68 ? How do they go in and whats needed ? Pics would hlp
brad20653 is offline   Reply With Quote
Old 07-30-2003, 06:55 PM   #2
Warbones
Navel Inspector
Warbones's Avatar
Good question. I have one on the passenger side of my 67 that will need swapping out as soon as I locate one that is without rust.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 07-30-2003, 06:59 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Inner fenders are usually pretty easy to install. I think there is about 7 bolts from what I remember, it's been awhile.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-30-2003, 07:20 PM   #4
bigvinnie
bigvinnie's Avatar
jack up the truck, pull the tire/wheel, unbolt the old inner fender and bolt in the new one...
Be safe.....use jack stands !!!
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 07-30-2003, 08:49 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't even need to pull the wheel really.
The real PITA will be when 1/2 of your bolts break from the rust.
Old 07-30-2003, 08:49 PM   #6
treefrog
USE JACK STANDS. I think if you turn the wheel a bit off center it makes it easier to get out. Really easy. Oh by the way, use jack stands.
TF
Did I mention, use jack stands?
treefrog is offline   Reply With Quote
