Old 06-22-2011, 07:12 PM   #26
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: EXTREMELY important information just released for ANYONE running a carb spacer!!!
Originally Posted by 67_C-30 View Post
NEEDS MORE CARB!!!
Cross that off the list. The 1050 produced little gains. I even wasted a bunch of perfectly good Holley HP bases. I tig'd them all together thus creating the world's largest throttle plate.
prostreetC-10 is offline   Reply With Quote
Old 06-22-2011, 07:15 PM   #27
7T2
Active Member
7T2's Avatar
Check your timing...by my calculations 275 degrees of advance ought to do it. You may have to cut a hole in your firewall for the vacuum advance to fit.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-22-2011, 07:17 PM   #28
prostreetC-10
My Carbon Footprint
Dang.....thought just crossed my mind that if I can't get this to work, I might as well scrap the "maxi-stack"......the world's tallest velocity stack. I was thinking how cool the maxi-stack would be on top of the mono-ram.
Old 06-22-2011, 07:25 PM   #29
prostreetC-10
My Carbon Footprint
Originally Posted by turp mcspray View Post
I've been waiting for your response all day. I just knew it would make me have a good laugh!
haha......hey, you just hit the grand posting milestone on my thread!
NO NO NO.....my motors can't run on distributors. I have two vertex mags being driven off a small sprocket in the rear of the block. I removed the cam softplug and engineered a drive system and a housing to support both mags.
Sorry....no pic available due to patents pending.
Old 06-22-2011, 07:49 PM   #30
LONGHAIR
Maybe you need to cut those velocity stacks so that you can make the opening foreward? Maybe the "ram air" would help? It obviously can't help with your idle issues though
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-22-2011, 10:45 PM   #31
Stocker
20' Daredevil (Ret)
Stocker's Avatar
I wondered about that.... and I see you also use invisible fuel lines
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-23-2011, 12:00 AM   #32
CaptMadDog
its prob those 4 holes getting in your way u need to try the sv1 from pro systems that and remove the squirters and just duct tape the fuel line so it flushes like a toilet that should do the trick hahaha
My build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=348729
CaptMadDog is offline   Reply With Quote
Old 06-23-2011, 01:02 AM   #33
prostreetC-10
My Carbon Footprint
Funny you mention Pro Systems. We are currently in litigation with them over the SV-1. They actually stole that concept from me. Below you can see my love assistant holding the SB-1 (single butterfly) prototype. Obvisouly....the first thing that catches your eye is the polished venturi for better direction of the air through the unit.
Actually, pro systems builds some bad to the bone stuff. I'll be interested in seeing if the single venturi really catches on and stays.
Old 06-23-2011, 01:58 AM   #34
BlazinC5
BlazinC5's Avatar
Was that a 2 barrel or a 4 barrel ,,, I got lost with that last post
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 06-23-2011, 06:17 AM   #35
7T2
Active Member
7T2's Avatar
I'm polishing my venturi right now...
1957 GMC Ambulance
1962 Belair Wagon
Old 06-23-2011, 07:05 AM   #36
The carb is a 750 HP. I tried jetting it down to a 650, a 600 and then a 390 but it didn't change the results. You can change the cfm with jetting right?
I dunno. I thought the size of the air cleaner and fuel line determined CFM. Maybe you need one of those vortex tornado maker thingies in there.
Old 06-23-2011, 09:13 AM   #37
bigguy69
dazed and confused
bigguy69's Avatar
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 06-23-2011, 09:43 AM   #38
prostreetC-10
My Carbon Footprint
Oh man......I almost had the coffee cup all the way up to the mouth when I read that. That could have been bad for the ole laptop. Just about crapped my pants. Good one!
Old 06-23-2011, 09:46 AM   #39
prostreetC-10
My Carbon Footprint
Well see I thought I read something about that. When using AN fittings, isn't -6 a 600 cfm, -8 and 800, -12 a 1200 and so on?
Old 06-23-2011, 08:29 PM   #40
1972RedNeck
1972RedNeck's Avatar
Bump for a very interesting thread.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-23-2011, 08:57 PM   #41
turp mcspray
turp mcspray's Avatar
Judging by your assistants summer shirt, it must be pretty warm there. If I were you, I would consider installing an air conditioner and setting it on MAX COOL.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-23-2011, 09:09 PM   #42
prostreetC-10
My Carbon Footprint
That's a good way to lose an eye!!!!
Old 06-23-2011, 10:12 PM   #43
BOZO
Old School
BOZO's Avatar
Wink Re: EXTREMELY important information just released for ANYONE running a carb spacer!!!
I'm afraid success with your intake is stacked against you. Maybe you could get some assistance from your assistant.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
Old 06-23-2011, 10:15 PM   #44
tasian
tasian's Avatar
man you got this set up all wrong the problem is your losing air velocity due to uneven angles on the spacers but luck has it that its a easy fix you need to wrap the inside in duct tape starting from the bottom and working up to increase the "tornado" effect but make sure you find some old school duct tape not that new crap
and last but not least take a buffing wheel down in there a few times cause remember ****lebuffout
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 06-23-2011, 10:18 PM   #45
CaptMadDog
We've been going about this all wrong.
I blame myself.
We need total surprise. An supercharger attack. The Beast will never expect it.
hahaha had to do it.
Old 06-23-2011, 10:37 PM   #46
prostreetC-10
My Carbon Footprint
We've been going about this all wrong.....
Are we talking about my assistant again??
Old 06-23-2011, 10:44 PM   #47
CaptMadDog
haha it applys to both i think hahah but if u know what movie that quote was adapted from ur totally awesome.
Old 06-23-2011, 10:49 PM   #48
prostreetC-10
My Carbon Footprint
sandlot?
Old 06-23-2011, 10:58 PM   #49
CaptMadDog
"ding ding ding" we have a winner hahaha that movie has alot of useable quotes hahaha
