Old 05-07-2011, 10:46 AM   #201
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Project 7deuce
Been busy with this thing finally got lots of parts just need to finish the odds and ends and get the new parts installed.. 1st on the list is to finish the half ass a.d.d. projects that I started on it but never finished...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-08-2011, 12:42 AM   #202
1971blazerguy
1971blazerguy's Avatar
Re: Project 7deuce
hey there mr french do u have any pics of the hinges for the hood i wanna do a reverse with mine but havent seen any pics of them yet?
1971blazerguy is offline   Reply With Quote
Old 05-08-2011, 09:57 AM   #203
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
http://www.67-72chevytrucks.com/vboa....php?p=3057585
MEMBER #6377
Project "7DEUCE"
Old 05-20-2011, 06:30 PM   #204
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Been workin on loose ends..... Welded up cab seam..
MEMBER #6377
Project "7DEUCE"
Old 05-23-2011, 12:28 AM   #205
67chevy1series
67chevy1series's Avatar
Re: Project 7deuce
it will be nice to see it all welded and then grinded dwon for that one peice lookk. keep it up frenchblue72
67chevy1series is offline   Reply With Quote
Old 05-23-2011, 12:47 AM   #206
es67chevy
es67chevy's Avatar
Re: Project 7deuce
Keep makin' forward progress!!
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 05-23-2011, 10:12 AM   #207
kev2809
low n' slo
kev2809's Avatar
Re: Project 7deuce
maybe i missed it but where did you mount your rear bags?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-08-2011, 12:12 PM   #208
bruceman1968
bruceman1968's Avatar
Re: Project 7deuce
Great build, nice lookin truck, subscribed!!!!!!
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 06-23-2011, 10:57 PM   #209
Junkpyl
Re: Project 7deuce
Nice looking truck, I like that hood trick. Used to have one of those Le Sabre's but sent it to the yard after the engine blew, wish I would have saved the hinges after seeing your truck
I know how the burned out thing goes, starting to come out of it slowly myself.
Keep up the great work
Junkpyl is offline   Reply With Quote
Old 06-23-2011, 11:05 PM   #210
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 7deuce
Cab looks good. That takes some serious time to lay down all those beads.
Old 06-24-2011, 03:48 PM   #211
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Thanks guys I keep buyin parts and finishing other house hold projects .. Hope to get back to her soon..
MEMBER #6377
Project "7DEUCE"
Old 06-25-2011, 12:10 AM   #212
oldman3
oldman3's Avatar
Re: Project 7deuce
Yeah it's a bummer when you have to keep up everything. Like I said in my post 1 day then another they all add up to a completed build, keep plugging away.....Jim
oldman3 is offline   Reply With Quote
Old 07-10-2011, 05:58 PM   #213
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Guess what I'm back on her with a vengeance pics tonight...
MEMBER #6377
Project "7DEUCE"
Old 07-10-2011, 06:02 PM   #214
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 7deuce
Cool!
Old 07-10-2011, 06:38 PM   #215
Junkpyl
Re: Project 7deuce
Hope you get more done than me, I pushed mine out into the driveway after church, looked at it for about ten minutes then pushed it back in. It's 104 here today. I thought I left Arizona
Old 07-10-2011, 10:26 PM   #216
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Eric (es67chevy)thanks for the poppers they seem like the will work with a little effort on my part... I did have to modify the mounting plates for them and I am thinking a little softer spring will help them work to there potential.. I also broke out the avs door releases,I have not installed these yet but they sure seem pretty nice kit comes complete with all cables and hardware..You can see where I had to take my dremel tool and grind down the welds on the backside of the poppers to make them fit flush.. My stainless screw store was closed today so I used some craptacular scews from the junk bin.. The poppers came with screws but they were weak sauce..
MEMBER #6377
Project "7DEUCE"
Old 07-10-2011, 10:36 PM   #217
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Finished welding up my new rockers finally.. These have been stuck on the truck for close to a year and now they are finally welded one and some rage applied to smooth out the cab corner to rocker joint.Here you can see the spacer I used to shorten up the door poppers... Welded up a large crack /tear in the passenger side door.. At some point before we got the truck someone had some rockin spark-o-matic 6x9's in the doors so I finally put on another coat of rage to smooth them back out...
MEMBER #6377
Project "7DEUCE"
Old 07-10-2011, 11:55 PM   #218
sams60gmc
sams60gmc's Avatar
Re: Project 7deuce
Sick..
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 07-11-2011, 07:41 AM   #219
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
No pictures uploaded??? Here we go agian with some pics.... Thanks sam hope your truck is keeping you motivated to get it finished unlike mine which goes in short bursts..
MEMBER #6377
Project "7DEUCE"
Old 07-11-2011, 07:48 AM   #220
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project 7deuce
Finally managed to locate some new caps off e bay for my wheels 52 bucks and they still dont look all that great... Also started sanding the cab roof seam,this took most of the day and just need to transition the corners to make them smooth..
MEMBER #6377
Project "7DEUCE"
Old 07-11-2011, 09:44 AM   #221
oldman3
oldman3's Avatar
Re: Project 7deuce
Roof looking good, keep at it.....Jim
Old 07-11-2011, 10:00 AM   #222
hbchevy
hbchevy's Avatar
Re: Project 7deuce
Are you getting rid of all the seems and rough edges? Going completely smooth?
- Scott
My 70 lwb build http://67-72chevytrucks.com/vboard/s...d.php?t=472866
hbchevy is offline   Reply With Quote
Old 07-11-2011, 10:17 AM   #223
sams60gmc
sams60gmc's Avatar
Re: Project 7deuce
I wish man. I've lost complete motivation. All I've done is pulled it to work in hopes of making it a runner..
Old 07-11-2011, 12:19 PM   #224
67cheby
67cheby
67cheby's Avatar
Re: Project 7deuce
tuned in ....lets see more !!
67cheby is offline   Reply With Quote
Old 07-11-2011, 12:58 PM   #225
VA72C10
VA72C10
VA72C10's Avatar
Re: Project 7deuce
Looking good! Hope you stay motivated for a bit so we can follow progress
