Old 06-25-2011, 09:03 AM   #8
DetroitDan
DetroitDan's Avatar
Re: Please help me!!
The main fusible link runs to the starter. You may also have overheated and hurt the headlight switch harness. Not burned out as it will still work sometimes, but it's probably pretty damaged. I'd follow it back from the switch into the harness that goes to the fuse box. That happened to me on a newer truck that had a lot of extra lights going through the headlight circuit. The backside of the switch would overheat and start to melt. Replaced switch a couple times, but the harness/plug that went to the switch was a little melted.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
headlights, help me, help me please, short circuit
