I've got the starter blues.help!!
I HAD REPLACED MY STARTER SELONOID 3 WEEKS AGO ON MY 62 WITH A 283 AND IT GAVE UP THE GHOST TODAY SO I HAD THE STARTER TESTED AND INSTALLED A HIGHER GRADE SELONOID AND IT WORKED GREAT ON A BENCH TEST,INSTALLED IT AND NOTHING,RAN A JUMP WIRE FROM THE MAIN BATTERY POST ON THE SELONOID TO THE INNER TERMINAL AND IT TURNED RIGHT OVER,RAN A TEST LIGHT TO THE INNER TERMINAL TURNED THE KEY TO THE START POSITION AND IT WORKED PERFECTLY,PUT THE TESTLIGHT ON THE OUTER TERMINAL AND TURNED THE KEY TO THE ON POSITION AND IT LIT ALSO BUT THE STARTER WILL NOT ENGAGE WITH THE KEY, ON THE SELONOID I HAVE 2 WIRES GOING TO THE OUTER TERMINAL AND 1 WIRE TO THE INSIDE ON THE SELONOID IS THAT CORRECT? NOW TO THROW A COUPLE OF MONKEYS INTO THAT MESS AT THE SAME TIME I REMOUNTED MY COIL ON THE FIREWALL ALONG WITH THE WHITE RESISTOR AND I DON'T THINK I GOT MY WIRES TURNED AROUND BUT AFTER TODAY YOU NEVER KNOW.I HAVE ONE WIRE FROM MY SELONOID HARNESS (GREEN)THAT I HAVE ON ONE SIDE OF THE RESISTOR ALONG WITH ONE WIRE (BROWN)FROM THE FIREWALL ON THE SAME END,ON THE OTHER END I HAVE 1 WIRE GOING TO THE COIL AND OF COURSE 1 WIRE GOING FROM THE OTHER END OF THE COIL TO THE POINTS. ANY IDEAS WOULD BE GREAT!
THANKS,KENT. ![]() ![]() |
"Where were you in '62?"
![]() Join Date: Jul 2004
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 06-24-2011 at 09:11 PM. |
Re: I've got the starter blues.help!!
thanks for the diagrams! now i know it's wired right.i took the starter out again and ran it on the bench and it worked fine and the starter wire on the selnoid is hot when you go to start position so i have my doubts that the ignition switch is bad and if i jump the battery wire to the starter post it turns fine so i guess i'm starting to think that one of the selnoid wires must be dropping amps somewhere so i guess that's what weekends are for.
thanks again! |
1961 crewcab
could it just be a badly corroded positive battery cable?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Sep 2005
Pull off the signal wire and use a test light on it to see if it lights up when key is turned. I've seen plenty of starters test good on bench but under load on vechle not work at all. The st6arter drive could be bad just no the soilned
#6 | |
thanks guys for all of your input and help. |
#7 | |
