Calling on you brake experts
Need help!! I bought a set of front spindles,rotors and claipers from a local. They were on his 64 c10 and I would like to install on my 62 c10. I know 60-62 is the same and 63-70 is different. what is the difference???
Re: Calling on you brake experts
60-62 had torsion bars and 63 + has coil springs.... I don't know if the late model spindles will work on a 60-62 but somebody will be by today that can answer that.
Resistance is Futile
Different balljoints; you could do a crossmember swap and use the parts.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Hey iehotrod.....
Wow, as far as the brake thing, I know that the '63's on up had..... Oh....$hit..... I thought you said "BROKE experts".
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
I don't think I would change the cross mamber for a 63 or newer suspension and disc brakes. At that point I would rather pick up a junked 73-87 newer c10 and do a complete swap including the rear end and convert to the 5 lug. with power steering.
If it all it is, is just ball joints that should be easy. I think... |
I did the reader's digest version.........balljoints and control arms are completely different design. You could have the spindles machined to fit the 60-62 bj's I suppose......or sell the spindles and get one's for 60-62 and use the rotors and calipers. These are the only options coming to mind at this time.
![]() Join Date: Aug 2004
arent the 60-66 frames wider than 63-66? I know the rear frame is wider on them, just wondering.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
![]() Join Date: Aug 2009
Thanks ProTrash64, it may be what I'm going to do.... I might just end up selling the whole set up I dont know. We'll see..
