Old 06-26-2011, 09:48 AM   #1
ubtripn
ubtripn's Avatar
Is there anything that can cause one side of the trucks lights to be dimmer.
On my drivers side the headlight, brake light and turn signal on the drivers side are dimmer?
ubtripn is offline   Reply With Quote
Old 06-26-2011, 09:54 AM   #2
mpotts64
mpotts64's Avatar
Re: Is there anything that can cause one side of the trucks lights to be dimmer.
check the ground, it happened to one of my trucks, I believe it was the purple striped wire that was not connected, grounded it to the radiator support and no more problem
No one ever fell to the top of a mountain.
When asked why I work on old trucks, I tell them: Been married 27 years, sons are pretty much gone, don't like the wife anymore and don't have a girlfriend, so, gotta do something, the old trucks are cheaper and less drama than a girlfriend -
mpotts64 is offline   Reply With Quote
Old 06-26-2011, 09:59 AM   #3
LONGHAIR
2nd on ground.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-26-2011, 10:19 AM   #4
68gmsee
Active Member
68gmsee's Avatar
X3 on grounding.
Dirty or corroded grounding is a big issue with these older trucks. Straps became corroded and broke off and some never re-installed when making repairs. Used to be that the mounting bolts served to help ground the truck but rust and dirt has made them lose their contact.
On my truck I installed 4 or 5 straps -engine to cab, bed to frame, the frame back to the cab. I placed one from the radiator support to the battery but one to the frame should be adequate. Lost all of my gremlins.
68gmsee is offline   Reply With Quote
Old 06-26-2011, 10:21 AM   #5
cdowns
cdowns's Avatar
all electrical connections need to b clean and shiny to work properly
if you're in a boat dont run aground anytime else it's a good way to solve problems
Old 06-26-2011, 10:21 AM   #6
71swb4x4
71swb4x4's Avatar
Not to beat this into the ground but I agree with everyone else.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-26-2011, 11:25 AM   #7
bosco200
bosco200's Avatar
^^^ All of those answers.
bosco200 is offline   Reply With Quote
Old 06-26-2011, 12:29 PM   #8
ubtripn
ubtripn's Avatar
Thanks guys, I will do all of that. =)
Old 06-26-2011, 01:16 PM   #9
ubtripn
ubtripn's Avatar
My battery negative cable mounts on the front of my intake mainfold. That one is clean but I wil go all the way through all of them and clean, fix and add to it if needed.
Old 06-26-2011, 02:36 PM   #10
71swb4x4
71swb4x4's Avatar
Check the grounds at the firewall that go from the block to the firewall.
An easy fix would be to run a ground from the negative battery post to the core support, but replacing the factory grounding points would look better.
Old 06-26-2011, 03:14 PM   #11
ubtripn
ubtripn's Avatar
Awesome, thanks. Good grounding will be my next day off project.
