Old 03-05-2011, 04:33 PM   #1
sleepingbag
sleepingbag's Avatar
Need a little help please!
Hello men, having a confusing little issue with the truck today, need some experts input. Started truck up this morning no problem, let her warm up for a bit, and went to take off... killed the motor...no biggie, BUT when I went to restart got a few weak whirrr, whirrr, whirrr sounds from starter, but no start! Came back a few hours later and truck started like it was brand new! Battery strong, alternator fine(per my tester) what could have caused this? No temp gauge so I dont know how hot it was running, thermostat prob? Thanks for any help in advance!
1967 GMC 3/4 ton Fleetside
350 ci Chevy
I'd rather do it myself and spend the extra 500 dollars
sleepingbag is offline   Reply With Quote
Old 03-05-2011, 04:40 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Need a little help please!
If you checked the alternator output and it was putting out at least 13.5 or more volts to the batter then it could be a starter solenoid or starter drive. You can probably get the whole starter complete for just a little more at Auto Zone.
68gmsee is offline   Reply With Quote
Old 03-05-2011, 04:41 PM   #3
mstrav1973
mstrav1973's Avatar
choke sticking on?
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 03-05-2011, 05:11 PM   #4
sleepingbag
Choke seems fine.. truck just didnt want to start while warm..
350 ci Chevy
Old 03-05-2011, 05:29 PM   #5
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
What kind of alt. are you running,interal or external?
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 03-05-2011, 05:39 PM   #6
463
463's Avatar
sounds like the starter solenoid http://www.rockauto.com/catalog/moreinfo.php?pk=42690 is weak or dry and it will not engage the starter drive http://www.rockauto.com/catalog/moreinfo.php?pk=42360;)
Trueman
463 is offline   Reply With Quote
Old 03-05-2011, 08:23 PM   #7
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Raise the hood and try starting it and see if the engine is turning over or just the starter making the noise. If the engine is not turning and the starter is making the whirring noise the starter drive is probably getting ready to take a crap. The starter drive has a sprag clutch and it is likely worn and may work intermittently for a while. Good luck, Roger
CaptRMW is offline   Reply With Quote
Old 03-05-2011, 09:01 PM   #8
Sammy
Headers? If so they are death to the starter without a shield of some sort.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-05-2011, 10:20 PM   #9
sleepingbag
Cold it turns over strong, hot it struggles to turn over at all. Seems heat related. Ill check starter solenoid tomorrow, may be the ticket...
350 ci Chevy
Old 03-05-2011, 11:06 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Probably Starter Heat Soak from the exhaust. Only shows up when the exhaust gets the starter hot...
LockDoc
Leon
Old 03-05-2011, 11:21 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My truck didn't have any starting problems until I changed carbs. The new Edelbrock Q-Jet was a lot leaner running than the Edelbrock 1405 I took off of it. I have headers, too. I had to add the heat shield to the starter, but it solved the problem.
Member Nr. 2770
Old 03-07-2011, 01:16 PM   #12
NoNeck
NoNeck's Avatar
I had a similar problem when I replaced a Holley 1850 on my small block with an Edelbrock 1406 carb. It would start just fine cold, but if I had driven for 15 to 20 miles then turned it off it would do exactly as described... like it was straining to turn over.
The starter was a new reman AC Delco hi-torque with heat sheild and wrap with matching solenoid. It started giving me "hot start" problems when I changed to the Edelbrock carb.
After numerous calls to Edelbrock tech, I determined that my carb would drip raw fuel down onto the intake floor after turning off a hot engine. It would also stink up my garage with a raw fuel smell. I never really figured out exactly why it did this, but I figured it was a needle and seat problem. I replaced the needles and seats, but still no better.
I changed back to my old grungy Holley and the problem magically went away.
NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 06-25-2011, 07:27 PM   #13
sleepingbag
Alright all, I finally sucked it up and bought a new starter from NAPA. Installed in truck and replaced battery wires as well. Believe I put the thing in correctly, but after all is said and done truck wont even turn over now. I rechecked all connections, still no start... now Im a little irritated and need some help on where to go next with this thing!
350 ci Chevy
Old 06-25-2011, 07:30 PM   #14
leddzepp
Moderator
leddzepp's Avatar
It might need to be shimmed.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-25-2011, 09:22 PM   #15
kevmic28
kevmic28's Avatar
Take it back and have them test the starter, might have sold you sa bad one.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
Old 06-25-2011, 09:34 PM   #16
68gmsee
Active Member
68gmsee's Avatar
Yeah, it's possible you got a bad one but before you go through all of the trouble of removing it, recheck all of the wiring to make absolutely sure it's right.
If you still have the coil here's a good wiring diagram: http://67-72chevytrucks.com/vboard/s...d.php?t=251165
Old 06-25-2011, 11:33 PM   #17
LockDoc
LockDoc's Avatar
You need to be a little more specific. Do you mean it won't turn over or it turns over but won't start. Does the solenoid click when you turn the key to start?
If you got the Yellow and Purple wires switched around it wouldn't do anything.
LockDoc
Leon
Old 06-26-2011, 11:37 AM   #18
sleepingbag
Yeah Doc, it is absolutely dead, no noise whatsoever. The heavy bastard fell while I was taking the old one out, and may have tugged the wire from the ignition switch, now that I think of it...as I had forgotten to loosen it prior to removal... better check..
350 ci Chevy
Old 06-26-2011, 11:51 AM   #19
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Been runnin' headers in every vehicle I have owned since the early 80's I have never had a problem with heat soak from headers getting hot. Not sayin' it can't happen... but headers aren't always the culprit.
Now back to the OP... sounds like you might have pulled that wire by accident when the starter fell. I would check it all the way back to the harness.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-26-2011, 08:42 PM   #20
sleepingbag
Thumbs up Re: Need a little help please!
Gary
Hot wire incorrectly placed, motor fired up like it was 1967, crazy how a new set of eyes can see the issues, thanks for the help all...
350 ci Chevy
