Old 06-26-2011, 02:01 PM   #1
68c10owner
68c10owner's Avatar
tilt column swap question
I picked this up from another member months ago and just now starting to think about the swap. Here is my question, how do I make this work? My truck is a 83 scottsdale without intermiten wipers but does have cruise control. the wiper switch is on the dash. The column I got is set up for intermitten wipers and the switch is on the column with the cruise control stuff all on one lever. What do i have to do to make it work? also, got it without keys, how do I change the lock cylinder without the key?
Anthony
68c10owner is offline   Reply With Quote
Old 06-26-2011, 08:15 PM   #2
80stepsideguy
Laid back freak
80stepsideguy's Avatar
Re: tilt column swap question
83 was the last year of the trucks with the wiper switch on the dash and in 84 they went to the column with everything from the CC to the wipers to the high beam switch.I think your better off looking for a 83 and down column to make it alot easier to install.I found 1 from a 82 GMC high sierra in a junkyard for 50.00. I had to have it rebuilt for 150.00.But for 200.00 its tight,its correct and i dont have to worry about any problems hooking it up and not working..
thanks
Pat
1980 chevy c10 step side restomod,
1970 cougar convertible 1 OF 24 ever built:
2014 Hyundai Tucson limited (daily driver).
80stepsideguy is offline   Reply With Quote
Old 06-26-2011, 09:53 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
as to pulling apart the column to change the ignition switch its pretty simple with the right tools... pull off the wheel use the compressor to compress the piece under the wheel.. remove the retaining clip, and once you slide out the turn signal switch there are pins or screws that hold in the ignition key switch
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 06-27-2011, 12:12 AM   #4
68c10owner
68c10owner's Avatar
thanks
Pat
Sounds like a good idea to me Pat. I think I`m going to do just that. i like easy. Thanks.
I know how to change them, done it on my old 75 GMC but I seem to remember having to turn the key a certain way to get it to pop out. Isn`t that right? I don`t have a key for this column. If I don`t need the key then I`m good. thanks.
Anthony
