Enthusiast
Bout to blow my lid off
Went to O'Reilly today to pick up a remaned Hydroboost unit. Guy claimed it comes with a brake pedal pushrod, so I was pretty happy about that. Well i show up and no, it only comes with a couple O-Rings, i tried searchin online at auto part store (napa, o'reilly, etc) but i cant find jack on where to locate a push rod. I'd use the one i have but its bent. Where the flip can i buy/find one?!
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
#2 | |
Conversion Truck Addicted
Re: Bout to blow my lid off
try rockauto
Thomas Quote:
What Hump?
Check wrecking yards in the area, and call teh dealer and see if there are any matches to other vehicles, I know my brothers chevy wagon had a hydroboost
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Enthusiast
I searched rockauto but it didnt seem to have it, or i just didnt look hard enough. I guess i'll just find one at the local wrecking yard. Any tips for the best way to remove the rod (without bending it)
What Hump?
I don't know about your particular year, but on my sons 2004 hd I had to remove the pedal assembly under the dash, It really was a pain in the neck, took over 3 hours to do. However when everything was open just pulled right out.
Hope this helps
Gentleman Jim owner x2
![]() Join Date: Oct 2010
Are you at all handy with a welder? I'd say just straighten your bent one out with a bench vise, and then get a piece of steel tube that fits nice and snug over the outside and weld it on so you re-inforce it. Just a thought...
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
my hydroboost came with a new rod in it the rods are different lenghts for different apps.
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
Enthusiast
Where did you get yours from?
God is good!
You might want to check with Auto Zone or Advance, or one of the others. Another option would be to have Oreilly's order another one. Sometimes what happens is the parts in the shops are scavanged by either the employees or others who have bought the parts and returned them. I know this from personal experience. What does your pushrod look like? I just removed my booster and may have an extra one.
Mando "It takes a smart man to know when he's stupid." -- Barney Rubble My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367 |
Enthusiast
Forgot all about this thread, woops. Still no rod yet. Anyways i called the local dealer and they said its measured from the bottom of the eyelet to the actuation something or other. The ACDELCO website says "measured from reaction piston to bottom of eyelet". Can someone elaborate on that? Do they just mean from bottom of eyelet to the base of the hydroboost?
I'll post a picture of my P.R. its roughly 178 mm long from top of eyelet to grommet end. And from bottom of eyelet to base of hydroboost is roughly 76mm.
Enthusiast
Update: Got a remaned unit from Cardone, i straightened my push rod (surprisingly not that hard), and used that. Got no noticeable leaks, save for a tiny one on the low pressure line on the Hydrboost side. Here's the latest issue: The brakes feel softer than they used to be and require a good deal more effort than the original unit. They used to be nice and stiff, now its just soft with much more pedal travel before brakes grab. I'm at a loss again.
On a side note i picked up a tach dash a few months back and finally got to test it out on the truck, every gauge works flawlessly save for the Tach, which spazzes out.
#12 | |
Posted via Mobile Device Posted via Mobile Device
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
