Old 07-30-2003, 01:08 PM   #1
Richard Dobson
Cab & body panel alignment
I have heard that in order to get all the body panels in proper alignment gap wise that the cab alignment can affect all of the alignment process. Any advice on how to shift a cab around and how adjustments can be made.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 07-30-2003, 03:29 PM   #2
1971Stepside
Almost Satisfied
1971Stepside's Avatar
You should leave the cab loose and adjust the front clip starting at one side and chase to the other. It takes several beers and a lot of patients!!! LOL
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-31-2003, 09:15 AM   #3
Z-72
It doesn't say a thing in the Haynes manual about serveral beers, I wish they wouldn't leave these steps out. Things go alot smoother when you have all the steps in order.
72-C-10-LWB-Big Block-TH400- PosiTrac Leaf Springs- A Dark Green Ford Eaten Machine. And those are not rust holes, there cooling vents..
Z-72 is offline   Reply With Quote
Old 07-31-2003, 10:03 AM   #4
Bernie
The argument runs as follows: beer kills brain cells, but not all of them. Evolution theory suggests that it only kills the weaker ones leaving the stronger cells to multiply. This is why people feel smarter after a few beers.
Bernie
Bernie is offline   Reply With Quote
Old 07-31-2003, 10:07 AM   #5
Southpa
Southpa's Avatar
Cheers! There is a certain order to installing/aligning everything too. First doors, then fenders, hood and cowl. Good luck with that, its a real PITA.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-31-2003, 02:52 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I think you have to start with the chassis sitting perfectly level. Then, the cab has to be level on the chassis. Let's see; there's the cab mounts (which rust and become weak), the cab mount rubber (which becomes weak with age). Then, there is the fact that when these trucks were built, the gap between the adjoining parts didn't have to be as precise as Lexus and Acura have gotten us accustomed to seeing. Door openings have to be square, but the windshield posts may have to be tweaked. It is a PITA, for sure!
Member Nr. 2770
