Old 02-02-2010, 06:58 AM   #1
BIG KRIS
BIG KRIS's Avatar
Fat man fab ifs
Are the ifs kits from fat man fab any good it says bolts on can run coilovers,bags,shockwaves drop front end 6inches with ground clearence issues,polished a arms.Wassup with it?
Flowershop Hip Hop & Street Rods
Dropmember
83 Custom Deluxe Almond on Almond
85 Silverado White on Red/Now Chevy LeMans Blue
Rendering in Truckin magazine vol 36 no. 11,2010
BIG KRIS is offline   Reply With Quote
Old 02-02-2010, 09:45 AM   #2
SCOTI
SCOTI's Avatar
Re: Fat man fab ifs
I'd drop w/stock truck stuff or a Dropmember before I'd consider a Fatmans bolt-in kit for these trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-02-2010, 10:40 AM   #3
BIG KRIS
BIG KRIS's Avatar
Re: Fat man fab ifs
I was just wondering what's to it I never hear about them but for the older classics.
Dropmember
Old 02-02-2010, 10:46 AM   #4
SCOTI
SCOTI's Avatar
Re: Fat man fab ifs
They bolt in the factory holes much like the other replacement c.members.
They utilize smaller brakes than what 71-87 trucks came w/from the factory (which require different rotors & calipers).
They require MII specific a-arms (stamped or tubular).
The main benefit of these over OE components is they give you slightly more clearance @ the same 6" drop vs. OE c.member & arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2010, 05:17 AM   #5
andrewmp6
Re: Fat man fab ifs
Fatman fab uses mustang 2 parts it will handle worse and probably ride like crap too.The reason the older car people love them is its a cheap easy way to remove a straight axle.They get a ifs front disc and rack and pinion cheap.It is a upgrade from a straight axle,But a newer truck like yours its kinda a dumb idea.You can get a dropmember and a everything needed for not much more it will ride better and not mess up your steering and suspension geometry.
Old 02-03-2010, 01:19 PM   #6
SCOTI
SCOTI's Avatar
Re: Fat man fab ifs
Most MII set-up's are engineered so the steering & geometry should be as good as a MII set-up goes (some even better).
I think they have their place. But, vs. an updated 71 & up GM truck suspension/brakes, I don't think they're worth it unless that extra ground clearance is worth the extra expense of having to get different control arms, spindles, calipers, & rotors.
If you have the money, the PB Dropmember or similar is the better direction.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-03-2010, 02:05 PM   #7
BIG KRIS
BIG KRIS's Avatar
Re: Fat man fab ifs
Had a nice long conversation with Nathan yesterday.
Dropmember
Old 02-03-2010, 06:14 PM   #8
Wild83C10
Wild83C10's Avatar
Re: Fat man fab ifs
Your looking for a coilover setup correct? You don't want bags?
Are there any other options out there for someone that doesn't want bags?
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 02-03-2010, 06:54 PM   #9
BIG KRIS
BIG KRIS's Avatar
Re: Fat man fab ifs
Have not really mad up my mind so we talked about different options. He a lot of help and a real cool dude he reached out to me to try and help me out. Cheese been talking to me about two trucks I like that were done over at Hills. Been talking to Jeff also.
Dropmember
Old 02-04-2010, 06:13 AM   #10
andrewmp6
Re: Fat man fab ifs
Think you can run coilovers on one of the dropmembers.
Old 06-28-2011, 03:28 AM   #11
ET702
Re: Fat man fab ifs
i have bought a truck and he had already had purchased the kit so i have started to put it on my 72 c10 step side. i do have 16 inch disc brakes and seem to be going on just fine. engine mounts are tubular and are getting installed on 9 of july and will have pics for you.
ET702 is offline   Reply With Quote
Old 06-28-2011, 08:27 AM   #12
m6z
m6z's Avatar
Re: Fat man fab ifs
Any more picts? It's always good to see all the options.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 06-28-2011, 07:27 PM   #13
tech@scottshotrods
Re: Fat man fab ifs
here is a pic of our coil over front with the optional splined sway bar we are running a forum special at the moment which is a killer promotion. Let me know if you have any questions
tech@scottshotrods is offline   Reply With Quote
