Old 06-29-2011, 07:50 AM   #1
72peace
72peace's Avatar
Will a spray-on bedliner de-value my truck?
Ok guys, I've heard arguments for and against spray-on bedliners. I've been thinking about getting my 72 Cheyenne longbed sprayed with some colormatching line-x, when a friend of mine says it will devalue my truck, so now I have doubts. There are a few bumps and dents as well as some surface rust in the bed. Should I try to restore the bed or just line-x it? Here's what I have: Also I just replaced the tailgate don't have new photos yet.
72peace is offline   Reply With Quote
Old 06-29-2011, 08:06 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Will a spray-on bedliner de-value my truck?
It's your truck, do as you wish. Unless your truck is 100% factory original and looks like it did the day it rolled out of the factory, I would have a liner sprayed in it. Thats just my opinion, others will come and they may vary.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 06-29-2011, 08:14 AM   #3
70cst
70cst's Avatar
But...if I was buying a truck for show and go the answer is I would not buy a truck with a spray in bed liner. But...if I was buying a DD and work truck than it would make me no differance. As Bishop Trucks said...its your truck. Do what best meets your needs. Good Luck. JMHO
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-29-2011, 11:21 AM   #4
brad_man_72
the boat guy
brad_man_72's Avatar
I wouldn't do it, unless you were going to keep it and haul firewood with it. Clean it up and hit it with some krylon.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 06-29-2011, 11:38 AM   #5
68gmsee
Active Member
68gmsee's Avatar
I wouldn't do it either. It's a good way to protect the bed but only if you intend to do some dirt, gravel, rock and other type of hauling and never intend to sell it.
I Sprayed Rustoleum on the bottom of my 68 and haul lumber, garden stuff including bricks and it still looks decent. I do use garage floor rubber tiles I bought at Lowes to place under the concrete products.
I've seen some ads "for want to buy" trucks that say "no spray on liner on the bed." Also, I talked to a few guys around here that had theirs lined since I was considering doing it on my truck but changed my mind after talking to them.
Here's another one. If you do intend to haul I've read where people absolutely oppose a non spray bedliner product but I've had one on one my other trucks and removed it sometime back. I saw none of the rust damage (other than some paint wear off) that has been mentioned by some. I will say that a bedliner is not for everyone though. Too slippery.
68gmsee is offline   Reply With Quote
Old 06-29-2011, 11:52 AM   #6
Gene
Gene's Avatar
It's your truck, do as you wish. I just don't see a line-x type bedliner hurting the value of the truck. I chose to have mine sprayed because it had light pitting all over the front of the bed floor, and I planned on a liner anyways so instead of having my paint guy smooth out the bed I just had him prep it and spray the liner, it hides alot of minor dents and pitting.
Gene is offline   Reply With Quote
Old 06-29-2011, 12:11 PM   #7
TheSeeker
I like the look of the color matched bedliner! I use my truck for hauling and would like to go this route, can you give some details on where/how much it cost to get it color matched? Thanks
TheSeeker is offline   Reply With Quote
Old 06-29-2011, 12:24 PM   #8
treveiger
treveiger's Avatar
^^^^ that's nice, seen a lot of guys at car shows doing this.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 06-29-2011, 12:25 PM   #9
72peace
72peace's Avatar
So, apparantly I'm not the only one with doubts. The line-x guy quoted $450 then an additional $200 to color match then another $100 to go over the rail, so $750 total. My paint guy quoted around $1500 to clean up and shoot the bed. I'm concerned about spending $750 if my value will drop $1000 (just a guess), so I'm out $1750. But if I go with the paint guy it would add value and I might break even. Still on the rail, so to speak.
Old 06-29-2011, 12:43 PM   #10
71 super
71 super's Avatar
If I see anice truck that has a spray in liner I automatically suspect a hard life or rotten bed or some combo of both. Neither is appealing to me. I will get famed but in my opinion it is a bandaid to keep from fixing correctly. With that said I just bought a 2006 hd with a spray liner in it- it is garbage, bed was not preped correctly and it is pealing off in sections- looks like crap, but now need to figure out how to get this visual abortion off...
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 06-29-2011, 12:52 PM   #11
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
That slippery factor is easily solved with a rubber mat. Also the protection you get with the liner and rubber mat combo is pretty amazing. Even with LineX i use a rubber mat and couldn't imagine not having it.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 06-29-2011, 01:43 PM   #12
72peace
72peace's Avatar
Of those that had theirs lined what were their complaints?
Old 06-29-2011, 01:44 PM   #13
Gene
Gene's Avatar
It can be a band aid, but in my case I planned on having a bedliner sprayed in anyways because I like the looks of the color matched ones. My bed was not perfect, but it was not a basket case either. I would have spent twice as much having the bed smoothed competely and to me that made no sense. I dont plan on hauling anything major but if I ever wanted to i'm happy to know I wont have to worry about scratching it, after all it is still a truck.
Old 06-29-2011, 01:46 PM   #14
Gene
Gene's Avatar
I dont know how much a line-x dealer would charge, I had mine done at the paint shop and basically it was a freebie.
Old 06-29-2011, 01:57 PM   #15
Redleg
Redleg's Avatar
It seems everyone has their opinion on this. However since my truck is a DD, and its current state is Rat. I would and will go with the spray in liner. I dont plan to go up over the rails though.
There is a good chance my TRUCK will see its share of TRUCK duties, classic or not. And the spray in liner will withstand that.
I can understand a numbers matching all original show truck owner would be completely mortified at the thought of a bed liner, but for DD trucks. I dont see why not......
The color matched option above is pretty sweet though. But if i had that much to spend and was putting a "pretty" bed in, i would go with the treated/stained wood flooring i have seen on a few.
Joel
Some trucks in the air, some layin' frame.
some are super cool, and some kinda lame.
Some kinda slow, and some really fast.
some run on 110,and some on pump gas!
Redleg is offline   Reply With Quote
Old 06-29-2011, 02:09 PM   #16
FrankieD
FrankieD's Avatar
I would second the rubber mat you can drop something in it and not damage the bed and then you still have the choice to paint it later if you want to make it a non hauler.
Mine has some dings amd dents on it so I am doing something different I got 4 sheets of heavy gauge brushed S S 9’ X 4’ for free from work and I have a friend at a fab shop with a big shear I am going to do the bed floor, tail gate and bulk head.
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 06-29-2011, 02:11 PM   #17
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
im putting a electric hard tonn. cover on mine i think i just rhino cover the bed since it would be cover and out of site
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 06-29-2011, 03:02 PM   #18
68gmsee
Active Member
68gmsee's Avatar
Thanks. Local Tractor Supply sells a thick mat over here. I guess I'm going to see if I can use that.
Peeling and cracking on a couple, fading on others. One guy hauls mineral blocks (rancher) and noticed a rust bubble had formed under the liner. Probably hairline crack and salt getting under it. It wasn't all one sided, I might add. Some guys liked them. One guy bought a truck with it on and didn't like it because he thought it cheapened the truck. That last one was the one that convinced me not to do it.
I'm not knocking anyone for doing it or wanting to do it, it's just not for me on my old trucks.
Old 06-29-2011, 03:03 PM   #19
longhorn70gmc
longhorn70gmc's Avatar
I am currently doing a spray in liner with my Longhorn and so far I am liking it. It is cost affective and if I do damage the coating I can reapair it myself. Also, as I do the spray in liner the bed is getting new bed wood. The bed wood is pine and has been preped and painted with quality marine/outdoor friendly paint done up in a black moteef. I live in the desert with extreme heat, so I want simple with good elements protection. A pretty bed like you normally see would be nice, but for me and where I live is not a good choice. It comes down to what you like and if you do sell it the new owner can easly remove it with sanding. I wouldn't think it would devalue your truck unless the coating was severly damaged and never touched up before the sale. Good thread, I am glad you asked this question.
R/
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 06-29-2011, 03:51 PM   #20
Vintage Windmills
Vintage 4x4s
None of those fit these trucks. I had to order a 72 x 98 universal thta made for the older pickups and cut to fit
Old 06-29-2011, 04:10 PM   #21
70cst
70cst's Avatar
A bed mat for a 73 and up fits pretty good. Thats what I use
Old 06-29-2011, 05:14 PM   #22
Spoof
Spoof's Avatar
If I was buying a truck I would be happier to have one without spray bedliner, so yes it would devalue the truck to me.
I just don't like the stuff...a nice steel bed looks great.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 06-29-2011, 05:48 PM   #23
k2rm
k2rm's Avatar
I had linux sprayed on mine about two years ago. No issues and I love it. Although people consider my truck show quality, I still use it for fun and light hauling. It is a truck afterall. Just two weeks ago we took it on a scuba/camping trip. I am glad I don't have to worry about scuba tanks or other toys scratching my freshly painted truck bed. I also have a pace edwards full metal jacket roll up cover.
Do I care about value? Nope, not planning on selling it ever. Been in the family since new and it is treated like it is part of the family.
k2rm is offline   Reply With Quote
Old 06-29-2011, 06:16 PM   #24
fastwillie 696969
~Rest In Peace~
nice color truck ^
Old 06-29-2011, 06:25 PM   #25
k2rm
k2rm's Avatar
Thanks Fastwillie. Don't tell my truck, but it is a toyota color.
