Old 06-29-2011, 09:58 AM   #1
cajundragger
Re: slamburban
I got the one that had the washers you install in the pump.
cajundragger is offline   Reply With Quote
Old 06-30-2011, 11:06 PM   #2
fredscarryall
fredscarryall's Avatar
Re: slamburban
i orded the washer kit from borgenson to reduce the pressure in the power steering. now i have to take the half the serpentine bracket system off to remove the pump from the suburban. so putting the rest of the front end together will have to wait till next week. i got the radiator back for the shop. fits really good and they did a nice job on the fan shroud.
fredscarryall is offline   Reply With Quote
Old 07-11-2011, 10:34 PM   #3
fredscarryall
Re: slamburban
got the lower grille support in. had to modify it a little for the radiator petcock
Old 07-11-2011, 10:37 PM   #4
fredscarryall
Re: slamburban
installed the grille,led turn signals and latching plate. also got the cowl vent and wiper motor in.
Old 07-11-2011, 10:57 PM   #5
99 to Life
99 to Life's Avatar
Re: slamburban
looking great, it's gonna be a real eye catcher for sure.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 07-11-2011, 11:38 PM   #6
iehotrod
iehotrod's Avatar
Re: slamburban
Coming along good. Big fan of that grill, I really dig the way look with fresh clean chrome.
iehotrod is offline   Reply With Quote
Old 07-12-2011, 11:23 PM   #7
fredscarryall
Re: slamburban
got the front bumper,bumper filler and headlight buckets in. also got the wiper motor and linkage in. tomorrow the hood ,fog lights and steering column go in and i start figuring out where to install the switches in the dash. then hopefully by the end of the week the plywood floor will be in and the back inner fender will get tacked on. also figured out why the brakes wouldnt bleed.sometimes it the simpliest thing. the calipers where on the wrong sides.so the bleeder where on the bottom instead of on the top. i dont know which is worse. taking 6 hours to unsuccessfully try to bleed the brakes or having a motorcycle guy walk up and instantly tell you whats wrong.
