Old 06-28-2011, 08:52 PM   #1
(joey)
(joey)'s Avatar
i need some help selecting shocks
hey guys.i tried the search but had no luck.im finishing my airbag setup on my build and im at the point where i need shocks.since im building my own mounting brackets i could use just about anything you suggest.im using a DeNominator-II 2500 and 2600 setup.what i would really like to use is a common stock shock that will work and i could easily order from a local parts store.reason being since i live in the great white north Canada, they think its a great idea to charge an arm and a leg to get it across the border from the U.S.thanks for any help fellas
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain)
http://67-72chevytrucks.com/vboard/s...d.php?t=434253
(joey) is offline   Reply With Quote
Old 06-29-2011, 04:55 PM   #2
SCOTI
SCOTI's Avatar
Re: i need some help selecting shocks
You're building your own shock mounts? Use OE replacement shocks of your choice. KYB GR-2's, Bilsteins, Monroe Select-a-Tracs.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-29-2011, 05:07 PM   #3
craig@ridetech.com
Formerly LSC71
I second that. They are great all around daily driver shocks and easy to get if you need a replacement.
craig@ridetech.com is offline   Reply With Quote
Old 06-29-2011, 06:01 PM   #4
(joey)
(joey)'s Avatar
ok thanks guys.so where im using the 01 sierra frame just go with a decent set of shocks for that year sierra?i was just worried they didnt have enough travel for using bags
Old 06-29-2011, 11:30 PM   #5
SCOTI
SCOTI's Avatar
That's what I would do. When I did the shock mounts for my 64, I used replacement shocks for the front & built the mounts to accomodate the range of compression/extension necessary for the bags (as measured from ride height).
I did use a different rear shock but only because @ the time I built everything, they did not offer a direct C10 replacement.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
