Old 06-27-2011, 07:10 PM   #1
jay55jay
Gauge pod installation
I'm installing a triple gauge pod in my 94 dually. I'm gonna do
Volts oil pressure and temp. Any hints on where to tap in for the
Senders thanks.
jay55jay is offline   Reply With Quote
Old 06-27-2011, 11:28 PM   #2
kevhill85
91 SWB 383
kevhill85's Avatar
Re: Gauge pod installation
Elec or mechanical
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 06-28-2011, 12:04 PM   #3
jay55jay
The temp guage is electrical and the oil pressure guage is mechanical. I am not sure where i can tap into the engine for these. thanks
Old 06-28-2011, 04:32 PM   #4
kevhill85
91 SWB 383
kevhill85's Avatar
Themp will hook up on the driver side head on the side. There will be a dark green wire to tap.
Mech oil pressure will hook up by the dist.
I will add pic in a min.
Old 06-28-2011, 04:38 PM   #5
kevhill85
91 SWB 383
kevhill85's Avatar
My temp is mech. It is located here the brass fitting is
No pic of the oil yet
Old 06-28-2011, 04:41 PM   #6
kevhill85
91 SWB 383
kevhill85's Avatar
Here you go
http://www.autometer.com/tech_installation.aspx
Old 06-28-2011, 05:51 PM   #7
jay55jay
I swapped out the mechanical oil guage for a electric one. I tried to tap off that green wire to run both the factory guage and the pod guage. When I do this both will not operate..
Old 06-28-2011, 07:41 PM   #8
kevhill85
91 SWB 383
kevhill85's Avatar
They both work on two deferent ohms. You would have to add a other sending unit somewhere . The elec oil perssure is a tan wire by the dist. It will be the same one or the other
Old 06-28-2011, 07:55 PM   #9
TURFKING
I have a '93 4.3l and the oil pressure wire runs down to sensor on the passengers side. I have wanted to run a mechanical gauge but the sensor wire runs between the block and oil filter. Really tight spot.
TURFKING is offline   Reply With Quote
Old 06-28-2011, 08:59 PM   #10
jay55jay
Ok I got the oil gauge done. I put a T and added the sending unit. I am stumped with the Temp. Can I put a T for that as well or will it effect how the gauge operates.. There is no where to Tap into. There is a water sending unit on each side of the motor and one in the front by the thermostat. Any suggestions thanks.,..
Old 06-29-2011, 11:28 AM   #11
jay55jay
Is it possible to run 2 gauges off 1 temp sending unit?
Old 06-29-2011, 01:36 PM   #12
kevhill85
91 SWB 383
kevhill85's Avatar
No, cause it would change the ohms reading if you ran two gauges off one sending unit.. You have to pick one or the other or add another sending unit.
Old 06-29-2011, 02:35 PM   #13
jay55jay
Can I add a brass T and put both sending
Units together?
Old 06-29-2011, 05:27 PM   #14
kevhill85
91 SWB 383
kevhill85's Avatar
Units together?
Yes, that would look kinda of cheesy.
Old 06-29-2011, 07:12 PM   #15
jay55jay
Yes I totally agree so I did a little more research.
I found a if in the intake in back of the carb problem solved
Nice and neat.
