Old 06-29-2011, 03:33 AM   #1
FickleFinn
Vin Plate
I am trying to decode the data plate on my left door jam, I am interested in paint, int, rear end ratios etc.
the Vin I get, but below it is a series of codes:
Vin: CS147Z157124
Below: BID DD C 67 136 (the DD is smaller characters and placed a 1/2 line up from the other characters.
Thx,
Mike
FickleFinn is offline   Reply With Quote
Old 06-29-2011, 04:44 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Vin Plate
you won't get paint, rear end ratios, bed type... not even engine size.
C 2 wheel drive
S inline 6 motor
1 1/2 ton
4 Cab with bed
7 1967
Z Built in freemont Cali
157124 is the 57124th truck off that line at that plant.
Old 06-29-2011, 11:13 PM   #3
FickleFinn
Re: Vin Plate
Thanks, I had translated the VIN.
Do you know if the truck would have come with PS and PB?
Old 06-29-2011, 11:19 PM   #4
Longhorn Man
Re: Vin Plate
sorry, misread the original post.
Inlines with power steering and brakes are hard to come by, the older, the harder.
a 67 with an inline os most likely not optioned with those, but that is just a odds comment, not a specific to your truck comment.
Old 06-30-2011, 01:14 AM   #5
FickleFinn
Re: Vin Plate
I thought as much, when I bought the truck it had a 283 with a 350 behind it, a camero steering column (thus the power steering) and power brakes.
The brakes are very grabby, will almost throw you thru the windshield!!
I am thinking about taking the power brakes off or maybe there is a way to reduce the boost??
Old 06-30-2011, 05:02 PM   #6
Longhorn Man
Re: Vin Plate
I would start with inspecting the brake condition. Out of adjustment (too loose) of shoe adjustment will do that, as will wet shoes (leaking brakes or axle seals).
