Old 07-02-2011, 08:12 AM   #1
cochino12
It followed me home?
cochino12's Avatar
tailgate window motor
am I just missing it in the LMC catalog or is the window motor not available?
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-02-2011, 11:22 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: tailgate window motor
73-91 suburban page 37 item 17
Hmm seems to have been omitted from the blazer catalog. I'll check at work today to see if they are the same part number or not and let you know tonight.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 07-02-2011, 12:19 PM   #3
Psycho71
Psycho71's Avatar
I researched it on rockauto.com, and couldn't find it for the k5 blazer, then found it for the k10 burb. A little cheaper than LMC, but core charge applies, making cost almost as much. Any chance the blazer has been converted? I'm not up to speed on options for that year model, but it odd that neither dealer lists it for the k5 but does for the burb. Either way, I bet the burb motor would work.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 07-02-2011, 11:58 PM   #4
BLE 'BURBAN
Ok I checked at work (GM DEALERSHIP, I work in parts ) and the motors are definitely different between the blazers and the burbs. The blazers motor is so obsolete that no one has one collecting dust anywheres across the nation.
However..... I did find a listing for a tailgate window motor listed on NAPA's websight with the following info.
Tailgate Window Lift Motor - Remfd
Part: RAY 4922265
Product Line: NAPA Electrical Motors
List Price ..........191.14
Core List Price......22.22
Features & Benefits
Completely Remanufactured With The Most New Top Quality Parts Available; Each Unit Is 100% Computer Tested At 3 Points In The Manufacturing Process. Guaranteed Performance Every Time.; Every Motor Is Assembled With The Precise Amount Of Lubricant. Ensures Quiet Operation And Long Life.; Gears Are Redesigned With A Stronger, Less Brittle Material. Gears Do Not Prematurely Wear, Strip And/Or Break Extending The Life And Performance Of The Unit.; Motor Magnets Are 100% Recharged. OE Performance And Reliability.; New High Quality Gaskets Are Used In Every Window Lift Unit. Prevents Water From Entering The Unit Eliminating Failure Modes Related To Water Penetration
Old 07-03-2011, 04:17 PM   #5
cochino12
cochino12's Avatar
thanks for the help guys, I think I'll just head to the yards and pull a few. Wonder why nobody else makes them?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 07-05-2011, 01:18 PM   #6
michael bustamante
michael bustamante's Avatar
I work at oreillys and they have em for 65 plus core chg.
1967custom
michael bustamante is offline   Reply With Quote
