#26 | |
Re: Increase MPG by 50-80% with a cold vapor fuel system?
how do you recognise a 4wd version from a 2wd?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#27 |
#28 |
4wd 700r4 has a short shaft while the 2wd version is much longer
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
#29 |
so, can I buy any 700R4 and do I need to find a seperate longer shaft, or is that directly connected to it?
#30 |
I would highly recommend looking for a 2wd version 700R4. The 4x4 tranny has a shorter output shaft and will not work in a 2wd application. You would need to locate and install a 2wd shaft for this to work. You need to tear into the tranny to do this. It can be done but it's more work then it's worth.
#31 | |
If you do put in a 700r4, make sure you get a 1987-1993 tranny. They were a better overall unit. 2wd 4wd |
#32 |
@Edahall: thanks for the info.
sorry for the misunderstanding guys. I have a 4WD. So I will need to look for a 4WD version. probably no way I can get one over here in the Netherlands. Anybody got a good one for sale here?
#33 | |
Conversion Truck Addicted
Thomas Quote:
#34 |
![]() Join Date: Sep 2010
Location: Oregon, The Beautiful Pacific Northwest (GOD'S country)
How hard is it to swap out my old 4 speed with granny low to a 6 speed in my '69 K10 which I believe has the NP205 transfer case? I hope I got that right! Also, what could I get the 6 speed out of so I know what to look for? Thanks!
In GOD I Trust ![]() 1969 Chevy CST K/10 SWB (Legs) 1969 Chevy C/20 LWB (Old Gray Mare) Donor 1972 GMC 1500 Sierra Grande (Orange Creamsicle) Sold 1979 Chevy C/30 Cheyenne Flatbed Dually (FatBoy) Sold 1991 Chevy Silverado Ext Cab (LowBoy) Sold 2008 Harley Davidson Electra Glide (Black Betty) Mark ~ US ARMY VETERAN 2nd ARMORED DIVISION 67th ARMOR |
#35 |
I ended up swapping my TH400-NP208 for a perfect swap in one day for a TH700R4 with NP208...even the crossmember was already in the correct spot.
waiting for first mileage results now
#36 |
Are you wanting a 6 speed manual or 6 speed automatic? I'm using an NV5600 6 speed manual in my 1990 Suburban with a NP205. There are others such G56 and ZF6. The NV5600's were offered in Dodge Cummins trucks from about 99-03. Afterwards, they went to G56.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#37 |
Have you looked in to a diesel swap tho ?
#38 | |
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
#39 |
Yeah, looking for a 6 speed manual that will bolt right up to my NP205 and hoping to not have to make any or at least little modifications to anything!!! Maybe what I need is a complete unit trans/transfer case and just swap it all out together!?
#40 | |
The other option might be to use a 6-speed ZF S6-650 manual out of a 2001 or later Chevy 4x4 truck with the 8.1L. The advantage here is it would bolt right up to your 350. However, GM didn't sell many 8.1's to begin with and finding one with a 6 speed manual is going to be even harder. Most people opted for the Duramax and Allison transmission. Why are you interested in a 6 speed? Do you do a lot towing? If you do a lot of heavy towing, having that close ratio makes a huge difference. If you're just looking for that extra gear for better cruising, consider another option. Install 3.08 or 2.73 gears and stay with your 4 speed. My 72 Chevy 4x4 4- speed has 3.08 gears and it cruises very nicely at 75 mph.
#41 | |
#42 | |
#43 | |
#44 | |
2.73's are only found in the used market from what I know. However, you could regear your current axles to 2.73's but it'll most likely cost you more money than just buying a set of 2.73 axles. If you've got 3.73's I'm sure you could trade with somebody and come out ahead.
#45 |
Sounds like I've got a project on the horizon!!! Thanks
