Old 06-27-2011, 01:25 AM   #351
67chevy1series
67chevy1series's Avatar
Re: '67 5.3L Build Thread
Originally Posted by 67C10BUB View Post
You're hired!!! The only requirement for my shop is that you LOVE C10's.
sounds good! ill have someone put a shop logo on the doors of my 67!
67chevy1series is offline   Reply With Quote
Old 06-27-2011, 07:43 AM   #352
killer71
killer71's Avatar
thanks!
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 06-27-2011, 12:36 PM   #353
eagleuh1
eagleuh1's Avatar
What, you wouldn't work on a C20 or 30 once in a while?
eagleuh1 is offline   Reply With Quote
Old 06-27-2011, 02:14 PM   #354
67C10BUB
67C10BUB's Avatar
I most certainly would!!! I think there might be a flaw with vdog's shop name. Ha ha.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 07-02-2011, 12:23 PM   #355
68 TT
Still plays with trucks
68 TT's Avatar
Good info, thanks. Any idea what might be causing my lean codes? I am thinking about getting a steam iron and see if I can see anywhere that the intake might be leaking.
I know this post is a little old but when my Tahoe pulled the same lean on banks 1 & 2 codes it turned out to be a bad intake gasket. It only had 80k on it when that happened.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-02-2011, 01:19 PM   #356
67C10BUB
67C10BUB's Avatar
Thanks for the help, but my issue ended up being that Speartech programmed my ECM for E85, but my engine was not an E85 compatible motor (non-E85 injectors). Once he changed the program the lean codes were gone. The truck runs GREAT now.
67 5.3L Build
Old 07-03-2011, 11:09 AM   #357
68 TT
68 TT's Avatar
Glad it was something simple.
Great build and fantastic truck.
When I have the funds I will be doing an LSx swap to my 67 K10 conversion and yours has helped in the planning of parts usage greatly. Thanks for sharing all the part number info. It helps a lot.
Old 07-03-2011, 11:10 AM   #358
68 TT
68 TT's Avatar
Originally Posted by tk-mpl View Post
67C10BUB, I see you used the factory battery cables.. Did you wire in the battery load module??? I am doin a 2007 5.3L swap and I noticed that my alt. is not charging. I didn't have the load module so I did not wire it in. I was wondering if you could just tuning the PCM to excite the alt with out that module???
Any ideas.....
Thanx
Trevor
GM sells a pigtail for the alternator that has a resistor built into it that makes the alternator function in retrofit applications.
If the LSx alternator is like the previous design (the CS-130 alternator) you can also wire it up to your stock alternator warning lamp and that will make it function also. I put the CS-130 in everything I build.
Old 07-03-2011, 04:56 PM   #359
Street Smart
Street Smart's Avatar
Thats good to know, i just did a 2010 6.2 into my `67, its charging but i would kinda like to see the "GEN" light work.
Do you have a part number and maybe a wiring diagram to the alt plug.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 07-03-2011, 06:45 PM   #360
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Mines hooked up as a one wire and tho it is charging...it only goes up to about 13.1v.
I have nothing plugged into it.........just the hot feed to the back.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-04-2011, 11:59 AM   #361
68 TT
68 TT's Avatar
This site has all the info you need for the CS-130 retrofit.
http://www.novaresource.org/alternator.htm
Pigtail with resistor: AC Delco #8078
http://www.oldengine.org/unfaq/10si.htm
Many of us have externally regulated alternators still so you will have to convert the wiring over to internally regulated first, then the wiring will work for the CS130 conversion.
Old 07-04-2011, 12:17 PM   #362
67C10BUB
67C10BUB's Avatar
Thanks for the kind words and I am glad to help. I try to always include part numbers so the next guy doesn't have to waste the time I did researching those little things. Good luck on your build. There are several of us on this forum that are glad to answer any questions.
67 5.3L Build
Old 07-04-2011, 12:19 PM   #363
68 TT
68 TT's Avatar
I just found out that the CS130D alternator uses a different connector than the older CS130 so the AC Delco part number I listed in post #361 will not fit the CS130D alternator on the LSx engines.
I'm pretty sure GM will have a version of the resistor pigtail for the CS130D but I don't have a part number for it.
Old 07-04-2011, 01:23 PM   #364
Street Smart
Great info!
Old 07-16-2011, 12:53 AM   #365
67C10BUB
67C10BUB's Avatar
I finally got my AC system installed and charged up today. Just had 1 leak at one of the fittings that I forgot to tighten. I will try to post pics of the install soon. Man, is it nice to have some cold air blowin', just in time for summer.
67 5.3L Build
Old 07-20-2011, 12:20 AM   #366
bandit01ws6
did you get the ac request working so it kicks up at idle. im not sure how different it is but i cant get mine to work. i tryed putting power to it and ground neitherr kicked up the idle. thanks and very nice truck.
bandit01ws6 is offline   Reply With Quote
Old 07-20-2011, 05:39 AM   #367
67C10BUB
67C10BUB's Avatar
According to John from Speartech, there is no AC request on the 2008 motors. It just senses the extra load and adjusts its idle accordingly. I believe this to be true because as soon as my compressor kicks on the idle raises slightly as needed.
67 5.3L Build
Old 07-20-2011, 09:48 PM   #368
c10-affair
Where's the pics?
c10-affair is offline   Reply With Quote
Old 07-22-2011, 12:18 PM   #369
67C10BUB
67C10BUB's Avatar
Here are the pics of the new AC system installed. The whole kit is the Old Air setup, except for the compressor blocks (Docs Blocks P#AA2210 and Ray's Auto Air & Heat P#06300739), the hoses (custom made by The Hose Man), and the compressor (stock 5.3L setup). The relay was added to turn both electric fans on when the AC on button is pressed.
67 5.3L Build
Old 07-22-2011, 12:19 PM   #370
67C10BUB
67C10BUB's Avatar
Here is a pic of the center console I made. It's not perfect, but it will work for now.
67 5.3L Build
Old 07-22-2011, 12:36 PM   #371
thor
thor's Avatar
i might have missed it, but what are the Doc's Blocks? what purpose?
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 07-22-2011, 12:44 PM   #372
67C10BUB
67C10BUB's Avatar
They are blocks that bolt to the factory compressor to adapt to regular male O-ring AC fittings.
67 5.3L Build
Old 07-22-2011, 12:49 PM   #373
thor
thor's Avatar
cool. thanks!
Old 07-22-2011, 01:02 PM   #374
Dano69c10
Dano69c10's Avatar
Man you aint kidding! This was one hot week in SoCal.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 07-22-2011, 01:13 PM   #375
68 TT
68 TT's Avatar
Great work.
Thanks for posting the part numbers too. That will help many of us.
