Old 06-27-2011, 02:12 AM   #1
1000000to1
1000000to1's Avatar
Trans question.
Anyone know what type of tranny is in my 58 Gmc? it is a three in the tree behind a 235 inline 6 and is there any way to bolt a 1980 olds 350 rocket to this trans? Thanks for your help.
2013 avalanche 5.3l
1971 Gmc 350 1958 Gmc fleetside
1000000to1 is offline   Reply With Quote
Old 06-27-2011, 10:45 AM   #2
OrrieG
OrrieG's Avatar
Re: Trans question.
I do not know when BOP (Buick Olds Pontiac) changed to the same bellhousing pattern as Chevy. Transdapt and Wilcap are two companies that have adaptors for different engine/transmission combos.
Old 06-27-2011, 03:56 PM   #3
1000000to1
1000000to1's Avatar
Re: Trans question.
Thanks that is what I was looking for.
2013 avalanche 5.3l
Old 06-27-2011, 04:24 PM   #4
1000000to1
1000000to1's Avatar
Re: Trans question.
Does anyone know what type of trans these 3 speeds are?
2013 avalanche 5.3l
Old 06-27-2011, 08:52 PM   #5
OrrieG
OrrieG's Avatar
Re: Trans question.
see if this helps.
http://webcache.googleusercontent.co...www.google.com
Old 07-03-2011, 01:57 PM   #6
Gene Sharp
Re: Trans question.
Borg Warner ?
Gene Sharp
Gene Sharp is offline   Reply With Quote
Old 07-03-2011, 08:14 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Trans question.
It should be a Muncie SM 318 if its stock. The buick, olds pontiac 3 speed transmissions are not the same. You should go with a Saginaw 3 speed mid 70's it has syncro 1st and is about the same length better able to handle a 350.
Old 07-04-2011, 04:03 AM   #8
1000000to1
1000000to1's Avatar
Re: Trans question.
Awesome thanks!
2013 avalanche 5.3l
Old 07-04-2011, 10:50 AM   #9
mr48chev
mr48chev's Avatar
Re: Trans question.
I've got a Saginaw three speed in my 48 and it is worlds smoother than the old transmissions were be they the stock ones or later style non syncro.
You don't need an adapter for that but will need a stick bellhousing for the Olds 350 (one of the BOP) units. plus the Olds flywheel. There should be plenty of bellhousings around because they had a lot of them in Firebirds but the flywheel might be a challenge although they had the Olds engines in the Firebirds too. You might even score a fourspeed in the process.
Old 07-11-2011, 03:51 AM   #10
1000000to1
1000000to1's Avatar
Re: Trans question.
Ya I'm going hunting tomorrow at the salvage yard to see what I can find, thanks for the info.
2013 avalanche 5.3l
