Old 05-31-2010, 07:52 PM   #1
sonseeker
sonseeker's Avatar
Question will 62 body parts fit on 64?
Have a friend that has a 62 with a good hood and fenders that i need will they fit,doors,how about the cab? its a lwb fleetside and i have a swb fleetside,or is it easier to ask what won't fit. Gonna try to take 2 trucks to make 1 nice one
sonseeker is offline   Reply With Quote
Old 05-31-2010, 07:57 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: will 62 body parts fit on 64?
all the front sheet metal is interchangeable, doors-60-63, then 64-66, same with the cab.
cabs will interchange with the frame with a little work to the front mount.
frame is 60-62, then 63-66, with the different front mount.
Old 06-01-2010, 01:04 AM   #3
Captainfab
60-66 Nut
To install a '60-'62 cab onto a '63-'72 frame, you'll need to drill new holes for the front cab mount bolts. If you want to go to the work, the recessed pockets for the bolt heads can be moved also. This will keep the bolt heads flush with the floor.
Old 06-02-2010, 04:37 AM   #4
Mr Pops
Ridin' Dirty
Mr Pops's Avatar
Originally Posted by Captainfab View Post
: If you want to go to the work, the recessed pockets for the bolt heads can be moved also. This will keep the bolt heads flush with the floor.
I'm not quite sure what you mean??? I'm also in the process of putting a 62 cab on a 64 chassis, so I want all the info I can get. I already drilled the rivets out and removed the mounts from the 64 chassis, (64 chassis and mount in pic) and am about to remove the front cab mounts from the 62 chassis.
1978 C3500 Crewcab (Project)
1979 C2500 Crewcab (Driver/project)
1988 R2500 Crewcab (Driver)
1988 V3500 Crewcab
1988 R2500 Crewcab (Mint, Ex Fire Dept)
1968 Chev Suburban (4x4 conversion) LINK
1970 Chev C20 Suburban (driver/cruiser)LINK
2005 Impala (Incognito vehicle)
2004 Yukon XL Denali (Kid hauler)
1947 Case tractor
Facebook Page(1000's of pictures of GM cars and trucks organized into albums)
YouTube Channel
Mr Pops is offline   Reply With Quote
Old 06-02-2010, 05:10 AM   #5
jonzcustomshop
1961 crewcab
here is a pic of 63 frame, and 61 mounts.
Not sure if changing he mounts will work (I think the frames were a different width through the center?), I think most just drill a new hole...
txfirefighter has had some experience with this..
Old 06-02-2010, 05:24 AM   #6
jonzcustomshop
1961 crewcab
here is TX firefigters thread with pics..
http://www.67-72chevytrucks.com/vboa...d.php?t=355711
Old 06-02-2010, 11:45 PM   #7
Captainfab
60-66 Nut
I was talking about drilling a new hole in the floor of the cab, through the front cab mount to line up with the '63-'72 front body mount bracket on the frame. The recessed pocket I mentioned is on the floor of the cab where the original front cab mount is. I wouldn't bother trying to change the front cab mount brackets on the frame. For one I don't know if that will work and the '60-'62's are welded onto the frame. Just drilling a new hole in the cab floor will be a lot easier and less work.
Old 07-03-2011, 10:03 AM   #8
CVA59
Fab, will this work the same in reverse order? I have a 61 frame and 63 cab.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 07-04-2011, 12:39 AM   #9
Captainfab
60-66 Nut
Yes that will work.
