#351 |
Re: '67 5.3L Build Thread
#352 |
thanks!
R.I.P. Killer 71 10/26/07 |
#353 |
What, you wouldn't work on a C20 or 30 once in a while?
#354 |
![]() Join Date: Aug 2010
I most certainly would!!! I think there might be a flaw with vdog's shop name. Ha ha.
67 5.3L Build |
#355 |
Still plays with trucks
I know this post is a little old but when my Tahoe pulled the same lean on banks 1 & 2 codes it turned out to be a bad intake gasket. It only had 80k on it when that happened.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#356 |
Thanks for the help, but my issue ended up being that Speartech programmed my ECM for E85, but my engine was not an E85 compatible motor (non-E85 injectors). Once he changed the program the lean codes were gone. The truck runs GREAT now.
67 5.3L Build |
#357 | |
Great build and fantastic truck. When I have the funds I will be doing an LSx swap to my 67 K10 conversion and yours has helped in the planning of parts usage greatly. Thanks for sharing all the part number info. It helps a lot.
#358 | |
If the LSx alternator is like the previous design (the CS-130 alternator) you can also wire it up to your stock alternator warning lamp and that will make it function also. I put the CS-130 in everything I build.
#359 | |
Do you have a part number and maybe a wiring diagram to the alt plug.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
#360 |
Truck and auto performance nut
Mines hooked up as a one wire and tho it is charging...it only goes up to about 13.1v.
I have nothing plugged into it.........just the hot feed to the back.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#361 | |
http://www.novaresource.org/alternator.htm Pigtail with resistor: AC Delco #8078 http://www.oldengine.org/unfaq/10si.htm Many of us have externally regulated alternators still so you will have to convert the wiring over to internally regulated first, then the wiring will work for the CS130 conversion.
#362 |
Thanks for the kind words and I am glad to help. I try to always include part numbers so the next guy doesn't have to waste the time I did researching those little things. Good luck on your build. There are several of us on this forum that are glad to answer any questions.
67 5.3L Build |
#363 |
I just found out that the CS130D alternator uses a different connector than the older CS130 so the AC Delco part number I listed in post #361 will not fit the CS130D alternator on the LSx engines.
I'm pretty sure GM will have a version of the resistor pigtail for the CS130D but I don't have a part number for it.
#364 |
Great info!
#365 |
I finally got my AC system installed and charged up today. Just had 1 leak at one of the fittings that I forgot to tighten. I will try to post pics of the install soon. Man, is it nice to have some cold air blowin', just in time for summer.
67 5.3L Build |
#366 |
did you get the ac request working so it kicks up at idle. im not sure how different it is but i cant get mine to work. i tryed putting power to it and ground neitherr kicked up the idle. thanks and very nice truck.
#367 |
According to John from Speartech, there is no AC request on the 2008 motors. It just senses the extra load and adjusts its idle accordingly. I believe this to be true because as soon as my compressor kicks on the idle raises slightly as needed.
67 5.3L Build |
#368 |
Where's the pics?
#369 |
Here are the pics of the new AC system installed. The whole kit is the Old Air setup, except for the compressor blocks (Docs Blocks P#AA2210 and Ray's Auto Air & Heat P#06300739), the hoses (custom made by The Hose Man), and the compressor (stock 5.3L setup). The relay was added to turn both electric fans on when the AC on button is pressed.
67 5.3L Build |
#370 |
Here is a pic of the center console I made. It's not perfect, but it will work for now.
67 5.3L Build |
#371 |
i might have missed it, but what are the Doc's Blocks? what purpose?
#372 |
They are blocks that bolt to the factory compressor to adapt to regular male O-ring AC fittings.
67 5.3L Build |
#373 |
cool. thanks!
#374 |
Man you aint kidding! This was one hot week in SoCal.
![]() ![]() It ain't yours, if you didn't build it! |
#375 |
Great work.
Thanks for posting the part numbers too. That will help many of us.
