Any idea if there are any differences between a 66 SWB and 70 SWB Frame? I have a 70 SWB that is tweaked. I also have a lead on a possible 66 SWB frame that is in much better shape which would save me time and money in the long run if it is the same as the 70.
Anybody know? Thanks in advance.
Chad |
Resident Curmudgeon
![]() Join Date: Dec 1999
It is NOT the same but I can't speak specifics.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
in WAY over my head
well, I'm not sure of the diffrences, but I've worked with a lot of these trucks and currently have a 69 frame for my 71 truck right now, and honestly aside from a few quirks, I dont see a difference.
your main differences will be bolt sizes for your front suspension, the bolts on the later models of these trucks were much larger than the previous, as far as holes and whatnot tho, a 67 may as well be a 72 and all points in between cos its fully swappable.. besides.. with alittle time.. there aint nothin you can't make work ![]() oh yea.. I guess I should also mention.. I beleive (dont qoute me here lol) that the 66s had a few extra holes in the rear of the frame to allow for helper springs? a bit more standard han the 67-72s? since the cab is different the body mounts are probablly off just alittle, and your very last crossmember is missing a hole for your wire harness.. if I were you I'd grab my 67-72 frame, line it up side by side to the 66 and just measure everything up, you will probablly need body mounts and your front and rear crossmembers |
Saving 1 truck at a time!
The only thing I know for certain is that my mid '67 frame is different than the late '67 and '68 - '72 where the power steering motor mounts to the frame. THe early '67 does not have the indentation on the frame to accomodate the later model power steering box since it had the cylinder assist version.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
