Old 07-07-2011, 08:00 AM   #1
eagleuh1
eagleuh1's Avatar
Dana 60?
Anyone know of a good source for the torque specs for A Dana 60. I've been googling and can't come up with any. Trying to replace outer hub seals and bearings for a replacement with 3.54 and posi. Had to drive to 6 different parts places before finding the 23/8 socket for the axle nut. Looking for axle flange bolt torque and spindle nut torque mainly. Thanks. 71 Dana 60.
eagleuh1 is offline   Reply With Quote
Old 07-07-2011, 08:36 AM   #2
shortbed70
shortbed70's Avatar
Re: Dana 60?
Pavementsucks.com and type in Dana 60 torque specs. I didn't see exactly what you were describing so you can look.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-07-2011, 09:43 AM   #3
Re: Dana 60?
http://www2.dana.com/pdf/AXSM-0053.pdf
Old 07-07-2011, 10:13 AM   #4
69sixpackbee
Re: Dana 60?
Tighten the first lock nut to 65 ft/lbs to seat the bearings. Loosen and tighten to 35ft/lbs. Back off 1/4-turn then tighten outer lock nut to 50 ft/lbs then bend the lock tabs. Beleve it or not but the Danas need .001"-.010" play when set up correctly. That's how I set mine up right before I left on vacation an I am sitting in so. Texas right now typing this reply. Hauling my big 'ol Lance camper all around God's country and no problems whatsoever.
I took those specs directly from the '72 repair manual.
Bud
69sixpackbee is offline   Reply With Quote
Old 07-07-2011, 11:13 AM   #5
eagleuh1
eagleuh1's Avatar
Re: Dana 60?
Thanks for the replies everyone. I can go finish tearing this thing apart and get it in the truck hopefully today. Jim
