Old 07-07-2011, 01:52 PM   #1
dukcaln
dukcaln's Avatar
steering wheel removal 72
can't imagine it is too hard.... what do I need to remove the stock steering wheel from my 72. Do I need a puller. Also how difficult to replace with an aftermarket wheel and what do I need. Is there a kit..... any tricks or things to look out for...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline   Reply With Quote
Old 07-07-2011, 01:56 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: steering wheel removal 72
This set pictured runs about $10 at harbor freight and will pull your wheel and many other things as well.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 07-07-2011, 01:57 PM   #3
67chevy1series
67chevy1series's Avatar
i have had look by just pulling the wheel it put up a little fight but it came off sometimes you may need a puller if you dont have one get a mallet wood or rubber and give the back of the steering wheel some good taps and it should break free, as for wrench size i dont rmember the correct size its a 13/16ths i think but can t be sure you will also need a phillps screw driver if your using a puller to take it off
67chevy1series is offline   Reply With Quote
Old 07-07-2011, 03:37 PM   #4
cdowns
cdowns's Avatar
i just loosen the nut then with my knees behind the wheel appling pressure i lake my 2lb hammer and with the end of the handle give a sharp blow on the nut and the wheel pops loose
Old 07-07-2011, 05:22 PM   #5
gotchamel
Having just recently changed out my 69's wheel,I was able to wiggle it back/forth and remove it w/o a puller.Seems like a straight pull or tapping with a hammer did nothing.
gotchamel is offline   Reply With Quote
Old 07-07-2011, 06:33 PM   #6
dukcaln
dukcaln's Avatar
so seems I will try with out a puler first. then get the kit for the wheel i want. once I have that its pretty much install the wheel. do they need to be torq to any specific spec.
SOLD 1972 chevy c10
Old 07-07-2011, 06:45 PM   #7
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Your local auto parts store will rent a puller for free.
Zoomin is offline   Reply With Quote
Old 07-07-2011, 06:55 PM   #8
gotchamel
Here is what I went with,4 spoke out of a vega????????Horn button took alittle patience but thanks to help here I'm honking away!
Old 07-07-2011, 07:32 PM   #9
dukcaln
dukcaln's Avatar
hmm thay vega wheel looks good. wonder if i could find at a wrecker place
SOLD 1972 chevy c10
Old 07-07-2011, 07:49 PM   #10
gotchamel
The 4 spoke wheel was used quite a bit by GM.The old Monzas had one with a cool horn button,had a spider in it.
Old 07-07-2011, 09:03 PM   #11
bosco200
bosco200's Avatar
Hey be careful if you just start pulling on it...sometimes they will fly off and hit you in the face
bosco200 is offline   Reply With Quote
