Old 07-07-2011, 06:33 AM   #1
Born Lucky
Cams anyone!
I am looking to replace my 292 camshaft.
I have searched the parts houses and some speed shops.
Every one over $200.00 and too agressive. Comp cams will
do custom grid. Does someone have leads?
Born Lucky is offline   Reply With Quote
Old 07-07-2011, 08:28 AM   #2
shortbed70
shortbed70's Avatar
Re: Cams anyone!
eBay. Are you looking for a roller or just hyd cam/lifter combo? Starperformance.com
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 07-07-2011, 08:29 AM   #3
awbrown
Re: Cams anyone!
I do a bit with 6 cyl. cams , is the engine stock ?? and what gears do you run ?? what are you looking to do with it ???
awbrown is offline   Reply With Quote
Old 07-07-2011, 09:26 AM   #4
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: Cams anyone!
$54.95 - $997.99
JEGS High Performance
http://www.jegs.com/webapp/wcs/store...y+292+camshaft
Summit Racing Equipment
http://www.summitracing.com/search/?...camshaft&dds=1
Langdon's Stovebolt Engine Co. | Specializing in GM 6 Cylinders
http://www.stoveboltengineco.com/
Hot Sixes the Performance inline 6 & V6 engine enthusiast website
http://www.hotsixes.com/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-07-2011, 06:17 PM   #5
Born Lucky
Re: Cams anyone!
Thanks all
I did call Summit Racing and was told they had nothing. Actually they refered me to Comp Cams and they have nothing, could pay for custom grind about $200.00.
I just want to button it up. It all started with a rear main seal replacement and things got larger from there. I could not remove the lifters so I banged them out and did not keep locations. I bought new lifters and now I read that it may be risky. Honest my cam looks O.K., I just figured I could buy a new cam for under $100.00.
My main goal is to keep her stock for now, or close to it!
Old 07-07-2011, 06:49 PM   #6
Rannos
Rannos's Avatar
Re: Cams anyone!
Why not just go back with a new 292? I assume you are talking about the comp cams 292. You can get it from Jegs for 129.99. Or if you want to go milder a 280 or 270 for the same price. You can also go with a Thumpr series for a lil more and get more of the sound with less requirements such as compression and head design.
http://www.jegs.com/p/Comp-Cams/Comp...46650/10002/-1
Rannos is offline   Reply With Quote
Old 07-07-2011, 07:16 PM   #7
Frizzle Fry
Frizzle Fry's Avatar
Re: Cams anyone!
He's talking about a 292cid 6cyl.
Frizzle Fry is offline   Reply With Quote
Old 07-07-2011, 08:24 PM   #8
Born Lucky
Re: Cams anyone!
Correct a 292 engine
It is a funny thing I personally called Summit Racing and Comp Cams and explained my part request. Both parties said no to a Cam for my 292.
Should I call Summit again?
Old 07-07-2011, 09:27 PM   #9
Rannos
Rannos's Avatar
Re: Cams anyone!
I thought about it after I posted and figured that's what he meant.
Old 07-07-2011, 10:23 PM   #10
1Bad62Pro/Street
If only COMPCams made Big Mutha' Thumpr™ cam for I6's!
http://www.compcams.com/Thumpr/index.html
Check these 292's out!
Old 07-08-2011, 08:56 AM   #11
awbrown
Re: Cams anyone!
http://schneidercams.com/252-56hchevyi6hydraulic.aspx make sure you select 292 from the engine size window....
Old 07-08-2011, 11:49 AM   #12
bama63
bama63's Avatar
Re: Cams anyone!
http://www.cliffordperformance.net/
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-08-2011, 07:48 PM   #13
Born Lucky
Re: Cams anyone!
I found one at Rock Auto by Sealed Power good price $100 plus.
I just can not beleive this thing started so slow. At first no parts now I am finding a few. I found Clifford and the rest but I did not want to pay so much.
Old 07-09-2011, 12:25 AM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Cams anyone!
voodoo cams
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-09-2011, 10:07 AM   #15
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Cams anyone!
When ya wanna run something a little "different"... that usually means you're gonna get hit harder in the wallet for any kind of performance stuff. Heck even the stock stuff can get pricey.
gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-09-2011, 01:11 PM   #16
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Cams anyone!
They show 2 cams for the I-6's
http://www.summitracing.com/search/m...s/?Ns=Rank|Asc
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 07-09-2011, 03:01 PM   #17
awbrown
Re: Cams anyone!
do not buy any cam that they say will work in a 250 ..It will not work .. 292 cams have the pump lobe in a different place and they are cut for connecting rod clearance !! if it is not 292 specific then you should pass...
