08-01-2003, 10:27 AM | #1 |
Rad fan shroud question?
When using electric fan setup, do I need a shrouded fan? Will a non shrouded fan cool a 4 core rad well enough?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
08-01-2003, 10:41 AM | #2 |
Probably not. Need more info such as size of fan, cfm, cooling problems when had mechanical fan?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
08-01-2003, 10:51 AM | #3 |
Life is Good !
I would say yes you need a fan schroud. The air needs to be pulled through the radiator evenly to cool correctly. Here is a post for another board about the fan schroud thing. Hope this helps, follow the link below. It will give you an idea of what you need. Good luck, Landon
http://www.myoldtruck.com/forums/sho...=&threadid=253
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
08-01-2003, 11:03 AM | #4 |
Any idea what kind of fans he used in that link?
08-01-2003, 11:29 AM | #5 |
Won't that limit the airflow throught the radiator when running at higher speeds like down the highway?
Save your money and do it right the first time. 1968 GMC short bed 1972 Cab 74 SB Chevy running gear |
08-01-2003, 11:34 AM | #6 |
Life is Good !
72gmcshorty, I have no idea but I can find out and someone or me will let you know.
Figment412, no I don't think it will make much differance. But then again I wont know for a few years, my truck is not done yet. I heard that the more even the flow of air to the radiator the better the cooling? but like I said I have no idea.
08-01-2003, 12:35 PM | #7 |
67-72 Addict!
I hear 93-97 Nissan Ultima fans are almost a direct fit and work good.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
08-01-2003, 03:51 PM | #8 |
I had a Nissan fan in mine until one of the motors started making noise. I think it was an early 90's Altima. It was dual fans and it fit perfectly. Now I have a Hayden 16" mounted in the shroud where the original fan would be. Works great.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
08-02-2003, 12:25 AM | #9 |
Old Skool Club
www.vintageair.com
They have a nice PDF catalog, page 70 of which has several fans and shrouds displayed. It seems like another A/C company makes an electric fan/shroud combo that is designed to fit our trucks, but I have not found it, yet.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
