Old 07-07-2011, 09:00 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Help for a disc brake conversion on 8-lug C20
I'm interested in putting disc brakes on my 69 C20 with 8-lug wheels. I have nice 8-lug wheels and would like to keep them. Is there anyway to convert my truck to disc brakes and keep the 8-lug wheels? I've done some reading on the "Drum to Disc Conversion" threads, but didn't see anything unless I'm missing something. I don't want to convert the fronts over to 5-lug wheels and have 8-lug wheels in the rear. What are my options?
Should this be in the suspension section?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 07-07-2011, 10:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Help for a disc brake conversion on 8-lug C20
There are a few threads here.
http://67-72chevytrucks.com/vboard/s...archid=2435485
Keith
Convert to disc brakes.
Old 07-07-2011, 10:09 PM   #3
lolife99
lolife99's Avatar
Another 100 threads here.
http://67-72chevytrucks.com/vboard/s...archid=2435493
If you have more questions,... please feel free to ask.
Keith
Old 07-07-2011, 10:49 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Your best bet is to find someone parting a 71 or 72 2wd 3/4 ton with discs and purchase the parts you need. Spindles out and proportioning valve should get the job done.
Ryan
1969 Chevy milk truck
Old 07-07-2011, 11:12 PM   #5
derotoreut
derotoreut's Avatar
I read though that working with 71-72 limits my options as far as parts is concerned and parts are more expensive. Would it be best to go with the newer years?
Thanks guys. Lots of reading to do.
~ Dan
Old 07-08-2011, 06:23 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Any square body donor truck will work just as well as 71-72 stuff and be much easier to find.
Anything that applies to converting 1/2 ton trucks to discs will apply to a 3/4 ton, as long as you use 3/4 ton parts. The procedure is the same, just different donor trucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
