Old 07-07-2011, 03:14 PM   #1
BMERDOC
BMERDOC's Avatar
Jeep Springs...AGAIN!
Sorry Guys, I know everyone has asked this question. I know the Jeep TJ '97-'07 and GM A body springs work. I have heard that WJ and XJ springs work. I found 08 jk springs on CL. I am assuming that just about any pigtail spring will work on the rear. Its just a matter of how much it will raise or lower the truck. I've heard of people massaging the rear cups to tighten around the pig tail becasue of the size of the coil. If anyone has lowered their truck using the '08 and up JK springs please tell me how they performed. The guy wants $40-50 for the springs but I am puposefully on a tight budget with this truck and I don't wanna added $50 to the junk pile.
ATTENTION!! I know some of you guys have cut your rear springs and I know many manufacturers make lowered springs for our trucks so please do not be tempted to offer these suggestions.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 07-07-2011, 03:23 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Jeep Springs...AGAIN!
BTW!! If you have any Jeep springs installed or laying around and know what they are from can you measure them? I would love some installed/uninstalled measurements. Please be as complete with your information as you possibly can!!
Nick Carter
Old 07-07-2011, 03:45 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Do not waste your time or money with rear Jeep springs. They MIGHT lower the truck 1/2 inch or so. They have a much weaker rating than factory springs, and your truck's hauling capacity will be greatly reduced. They are the same height as factory springs, so the "lowering" you get is from the weaker rate. I put them on my truck for a week, then pulled them and threw them in the trash and bought proper lowering springs.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-07-2011, 06:30 PM   #4
BMERDOC
BMERDOC's Avatar
Originally Posted by BMERDOC View Post
I am puposefully on a tight budget with this truck.
DANG!! Didn't add "Don't do it" to the ATTENTION portion of my post!
I'll explain my tight budget and it'll make more sense. The inspection sticker on my truck expired 5/98. I can only guess it was taken off the road in the year prior to that. I do not know what condition this truck is in and I am not willing to invest $800 into a high zoot drop kit until I know the engine isn't gonna grenade, the clutch isn't gonna slip like crazy and everything is rock solid. I'd be very mad at myself if I had a truck with a nice 4/6 drop and a hole in the block.
I installed 255/60's on the front and 255/70's on the rear. I need to close the wheel well gap to make it look better. I already put together the homemade block kit ($37) and was gonna install it to level the truck. I was thinking I could install the Jeep springs, cut off a coil on the front and trim off half of the bumpstops which would give me a 2/4 drop for $40 (minus the blocks). That kinda money I dont mind spending.
I am not on a budget because I am broke. I am on a budget because I don't want to put money in one place only to find out I needed to put it somewhere else.
BTW, the pic demonstrates how worried I am about hauling capacities.
I completely respect your opinion. Believe me I am a BMW mechanic and I'm all about doing something right. I know this is temporary and it will change once a shakedown period is complete and I feel more comfortable about this trucks reliability. Again, it comes down to "correct" and "good enough".
Nick Carter
Old 07-07-2011, 06:49 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
I'm with you and with member leddzepp.
DON'T spend $800 on a lowering kit,... right now.
DON'T waste your money on crappy Jeep Springs.
Spend $99.99 from POL on some drop springs.
No money wasted.
You can add other suspension components to them later.
Suggesting Jeep springs is like suggesting torching the stockers.
Check out a board supporter,... www.PerformanceOnLine.com.
Look here:
http://www.performanceonline.com/196...SPRINGS-16832/
Keith
Convert to disc brakes.
Old 07-07-2011, 07:09 PM   #6
BMERDOC
BMERDOC's Avatar
Ok,then forget it. I can get the CL springs for $40, Chevelle springs from NAPA for $70 or C10 drop springs for $100+shipping. Hopefully shipping doesn't bend me over the barrel. Buying right the first time means I don't have to buy again. If I bought $40 springs and had to replace them for whatever reason I'd have that much more money involved in the process.
Nick Carter
Old 07-07-2011, 07:56 PM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
They drop the rear about 4", they are super thin and bottom out with 40 lbs in the bed of the truck. I have some i'll sell for $20 plus shipping if you have your heart set on em.
John
1999 Toyota Tacoma 4x4
Old 07-07-2011, 08:05 PM   #8
BMERDOC
BMERDOC's Avatar
Thanks but no. If I had a free pair layin around I may be tempted to throw them in. I asked for advise and got it even if its not what I wanted to hear. I'll buy right the first time, still cheap but right.
Nick Carter
Old 07-07-2011, 08:06 PM   #9
leddzepp
Moderator
leddzepp's Avatar
I understand "correct" and "good enough". I used Jeep Springs in the rear, because I am on a budget as well. They did NOT lower the truck any more than 1/2". There is NO point in using them
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-07-2011, 08:10 PM   #10
oldblue1968chevy
I remember ya talkin' bout em. I got pics of my truck it dropped it 4 5 inches i bet rode like crap cause it bottomed out all the time...
John
Old 07-07-2011, 08:13 PM   #11
leddzepp
Moderator
leddzepp's Avatar
The only way I can figure it dropped your truck that much is because you have a long bed....my truck is a short bed. I bet the weight difference is why yours dropped. Like you said, add 40 lbs to the bed and it bottoms out.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-07-2011, 08:22 PM   #12
BMERDOC
BMERDOC's Avatar
10-4
Nick Carter
Old 07-07-2011, 08:30 PM   #13
oldblue1968chevy
Try it and see if you like em (since you already have them...) chances are you'll be saving up for real drop springs, I think ECE makes heavy duty 4" springs for burbs etc.
John
Old 07-07-2011, 08:37 PM   #14
BMERDOC
BMERDOC's Avatar
Ok,so lets move to the panhard rod. If I envision this correctly, the rod gets too long when the rear is lowered. So all I gotta do is put my truck on the alignment rack, raise it, remove the bolt on the frame, measure the distance from the bracket bolt hole and the rod bolt hole, lop off the end, fishmouth the end of the rod weld the end back on, if I did everything correctly it should line up and be correct for the new ride height. Whats with the super long panhard rods that bypass the connection at the centersection of the diff?
Nick Carter
Old 07-07-2011, 08:59 PM   #15
lolife99
lolife99's Avatar
The "longer" the bar,... the less side-to-side movement thru-out the suspension travel.
Keith
Old 07-07-2011, 09:08 PM   #16
BMERDOC
BMERDOC's Avatar
Gotcha! Thanks! I can't envision this dynamically. All I can see is the arc instilled in the vertical movement if the rod length is incorrect.. So if I shorten the rod it will not help true vertical movement of the axle?
Nick Carter
Old 07-07-2011, 09:30 PM   #17
VA72C10
VA72C10
VA72C10's Avatar
sent you a pm. I agree on the jeep springs from everything I've heard here and from others who've tried them.
Old 07-07-2011, 09:30 PM   #18
Hubscrub
Cruzin
Hubscrub's Avatar
not the best route but, you could always do the no cost rear lowering by cutting the rears my wife's 67 is done that way and i know a few others to. i probably will install regular drop springs though
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 07-07-2011, 09:59 PM   #19
AustinScott
AustinScott's Avatar
WOW! never seen CUT rear springs, looks a bit scary
AustinScott is offline   Reply With Quote
Old 07-07-2011, 10:15 PM   #20
bigguy69
dazed and confused
bigguy69's Avatar
That was done to my truck by the po. Then they welded flat bar to the spring so the cup would work. It rides ruff. I will see if I can get pics tommorow.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 07-07-2011, 11:16 PM   #21
BMERDOC
BMERDOC's Avatar
Saw it in other posts during my research. That is why I asked not to see it. I can hardly stand to look at it.
Nick Carter
Old 07-08-2011, 02:19 AM   #22
leddzepp
Moderator
leddzepp's Avatar
My "rear end" is puckering just looking at it.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 07-08-2011, 04:08 AM   #23
68chevyLQ4
68chevyLQ4's Avatar
68 Chevy C-10. swb fleetside. 6.0 4L80E swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=460877
68chevyLQ4 is offline   Reply With Quote
Old 07-08-2011, 10:41 AM   #24
oldblue1968chevy
(that is on hubscrubs wifes project truck, I think he is secretly trying to get rid of her or something) yall oughta see the panhard bar mount
just giving you a hard time nate, (he is a really nice guy)
John
Old 07-08-2011, 10:44 AM   #25
oldblue1968chevy
jeep springs in the rear late 90's TJ
John
