07-07-2011, 09:18 PM | #1 |
TBI 700r4 lock up ?
So i just got done a couple weeks ago with my tbi swap adventure. I put a 350 with 700r4 in my 71 c10. I used the wiring from a 90 burb.
I only have two problems. 1. I used the hole harness and took out only acc. so i have every thing in harness still like drac adl. every thing remained the same. However the 700r4 wont lock up in 4th and the only thing missing is the abs module. the module shows a pin for vss and tcc lock up. Do in need the abs module to complete the lock up process. Side note 700r4 rebuilt by shop and tv was adjusted professionally. 2. The tbi seems to be running rich with a fowl smell. I cleaned the tbi and replaced the gaskets. I do have a small leak from the collector which is about 3 inches outward flow from the o2 sensor. not sure if thats my prob. Any help or knowledge would be greatly appreciated. |
07-08-2011, 11:04 AM | #2 |
Re: TBI 700r4 lock up ?
The lockup signal from the ecm is a ground that goes straight to the plug on the trans. The power comes through a brake switch that applies 12v when the brake is not applied.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
07-08-2011, 01:48 PM | #3 |
I agree. You do not need ABS module signal on a 700R4 lockup.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
07-08-2011, 02:23 PM | #4 |
Its a Truck Thing......
Check the coolant sensor if it is running rich, known problem with TBI's. Some were so sensitive with the resistance that you could get new parts that would throw it off.
I had guys just use a toggle switch to lock up the converter. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time |
