Old 07-28-2003, 10:38 PM   #1
sider68
sider68's Avatar
Question Rough Idle
I took my son,s 81 GMC pickup with a 250 in line six in to get certified and safety checked.It has 75,ooo miles on it.I asked the mechanic to tune it up as it had a very slight miss to it,but lots of power.He changed the distributer,rotor and plugs.Now it idles rougher than before.The mechanic claims those motors were always rough running.What should I do now as I don,t want to cause any damage driving it like it is?I heard those engines were very long lasting and dependable.
sider68 is offline   Reply With Quote
Old 07-28-2003, 10:49 PM   #2
bigd65
bigd65's Avatar
sounds like the mechanic neds to be SMACKED.
seriously, check all the plug wires and make sure they are firmly snapped to the plugs as well as the distributor cap. then you may want to check the firing order or even the adjustments on the cab. its reall hard to tell if not looking at it. also check all vacuum hoses and make sure one hasnt been pulled loose or even cracked for that matter
2004 Silverado Crewcab (Dark Spiral Gray)
bigd65 is offline   Reply With Quote
Old 07-28-2003, 10:56 PM   #3
r0lf-
Hotwheels?
r0lf-'s Avatar
They are rough as hell idling engines. Thats just the motor.
They are torqey little suckers especially. You might think something is wrong with the motor but its not, you'll get used to it. Thats kinda what makes the motors so cool!
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 07-28-2003, 11:02 PM   #4
Russell
Professional Grade
Russell's Avatar
My whole truck shakes when it idles, the engine is in perfect running condition, so I think that chances are it is fine. Definitly gives the truck a very powerful sound and feel...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 07-29-2003, 02:13 AM   #5
Low83
Talking
Possible Vacuum leak ???
Low83 is offline   Reply With Quote
Old 08-01-2003, 10:48 PM   #6
sider68
sider68's Avatar
:p RUSTY I know you are back and will have an answer
Old 08-01-2003, 11:01 PM   #7
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
check the ignition wires sometimes they screw up after being moved etc. also a cheap cap or rotor can cause a problem but sometimes it is just the motor but being it ran better before the mechanic messed with it, id tend to say he touched something wrong
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 08-01-2003, 11:10 PM   #8
sider68
sider68's Avatar
He replaced the cap and rotor but not the wires.There were new spark plugs in it.Should I replace the wires?
Old 08-02-2003, 03:57 AM   #9
Nvbowtie
Nvbowtie's Avatar
If you had a plug wire tester I would do that first,
I made the mistake once of replacing all my wires at tune up and it started missing off and on, took to two shops, and then broke down and took to GM dealer,
I paid 199.54 for them to find and replace a bad plug wire that was new, but had a internal break, talk about being pissed !!!!!!!!!!!!
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 08-02-2003, 09:36 AM   #10
maineiac
If he replaced the cap and rotor did he touch the timing too? Could be he set it up to wrong settings also if he used a generic cap and rotor half the time they are not worth the cheap plastic they are made out of check it and see if it is carboning up on one plug or another. I have bought two trucks now that had "engine " problems to find out that they had the firing order wrong.
Steve
maineiac is offline   Reply With Quote
