Closed Thread
Old 07-10-2011, 11:36 AM   #2476
JON70CST
JON70CST's Avatar
Re: What did you do to your truck today!
Installed a Holley electric fuel pump, and installed a new vacuum modulator on my turbo 400 as the last one was allowing tranny fluid to pass through to the vacuum line right to the carb.
JON70CST is offline
Old 07-10-2011, 12:59 PM   #2477
Stringer
Tightened my steering gear a little. Big difference. Should have done it 6 months ago.
Stringer is offline
Old 07-10-2011, 06:19 PM   #2478
TX6T7
TX6T7's Avatar
Removed heater core/box, removed cowl panel from below windhield, cut out the old 6cylinder exhaust pipe and muffler. Removed tail lights, reverse lights, clutch pedal, door panels, instrument cluster
Also had to grind off some welds. The previous owner installed a sheet of steel that covers the wood bed and he welded it to the front, sides and back of the bed. It was a PITA, but luckily i had enough patience.....and a grinder with 3" cutting wheel.
1967 Chevy swb stepside-work in progress
2005 GTO-daily driver
2001 F250-weekend car crusher
1956 Chevy Pickup-sold
TX6T7 is offline
Old 07-10-2011, 10:15 PM   #2479
profe56
I did cut a low hump cover the same border as big hump to install it in my truck.
I've a camaro floor shifter but the cable is short with the big hump and with the low hump i'll have about 2 1/2 inches and I expect now will move more smooth and soft.
profe56 is offline
Old 07-10-2011, 10:29 PM   #2480
project 67 sub
project 67 sub's Avatar
went to the brothers show and won lowest truck
project 67 sub is offline
Old 07-10-2011, 10:46 PM   #2481
GMC69
GMC69's Avatar
Took the truck to cruise night and decided to adjust the timing once again to try and get rid of this damn stumble on low speed driving. Now sitting at 12BTDC and will get my vacuum gauge to adjust the idle mixture this week hopefully.
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline
Old 07-11-2011, 08:38 PM   #2482
mdaven@aol.com
Finally removed the dash pad for dyeing. Reinstalled the ignition switch. Removed some more PO wiring tangles. Mounted my door panel trim in preparation to mounting the door panels (powdercoated). Will be reinstalling the seat, seatbelts, ashtray, radio blockout. Removing the metal radio mount from under the dash. Probably going to a single, oil pressure only, gauge set-up. Slowly completing the interior. Soon will get back under the hood to correct some more wiring issues, then hit the road.
mdaven@aol.com is offline
Old 07-11-2011, 08:58 PM   #2483
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
mORE BOARDSANDER ACTION TODAY....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 07-12-2011, 03:37 AM   #2484
mmmBoost
Installed pushrods and roller rockers yesterday
Installed intake, carb, and temp installed valve covers
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline
Old 07-12-2011, 08:06 PM   #2485
RagingAsian
RagingAsian's Avatar
Washed and waxed everything. Powerwashed the undercarriage and engine and bed. Now I drive it and save up for some nefty goodies.
Susie-Honda Accord Coupe|Elisa-1968 Chevy C20
Holdin' it down in the 520
RagingAsian is offline
Old 07-12-2011, 08:58 PM   #2486
GMC69
GMC69's Avatar
Bought some new Stainless Steel door sills with the chevy emblem on them to replace the chrome ones in there now that the passenger one is a bit rusty in one corner. Normally I would leave it but this year will be my first car show that I have a vehicle to enter and I want the truck as close to perfect as possible.
Here is a picture I found online of what it looks like.
Mike
2019 Silvedrado 4x4
GMC69 is offline
Old 07-13-2011, 08:43 PM   #2487
Rob H.
Rob H.'s Avatar
I cut the right rear corner off the bed for a buddy to use on his truck, then took the torch to the bed bolts and took it off the frame, found out there is a serious rust problem, but hey, that's what makes it a project right.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 07-13-2011, 09:09 PM   #2488
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Took my rear end and driveshaft to be sandblasted and painted.
Member Nr. 2770
ChevLoRay is offline
Old 07-13-2011, 09:44 PM   #2489
FRENCHBLUE72
PROJECT 7DEUCE
More mud....board sander and more mud..... this is getting old..
MEMBER #6377
Project "7DEUCE"
Old 07-13-2011, 10:57 PM   #2490
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Went outside this AM to my DD 68 started it backed up a few feet and it died.
Bad ?modulator? (half moon thing in dizzy) luckily I had a spare
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 07-14-2011, 04:22 AM   #2491
phyllis1224
i had bought some [URL="http://www.12vcity.com"]car parts, wanted to travelling
phyllis1224 is offline
Old 07-14-2011, 06:14 AM   #2492
mabel
I was actually thinking of selling it! And I am looking for a new one too! Anyone here would like to give me any suggestions on what to buy next?
mabel is offline
Old 07-14-2011, 11:03 PM   #2493
Jeffs70
Jeffs70's Avatar
well for the last few days I have been doing body work inside the bed. and on it to get it finished where i am happy enough. I went and laid some paint this week and here is what so far I have come up with. dont mind as some of the paint is still wet but it gives a good look IMO I also will be spraying the center section gloss black in a few days. and dont mind I still have some minor body work to do.
Jeffs70 is offline
Old 07-15-2011, 01:34 AM   #2494
Tomahawk30
Tomahawk30's Avatar
Starting to dismantle the front clip to replace the drivers side fender and hood. Got the grille, trim, and cowl pulled tonight before it got too dark...
1979 Silverado C10 Shortbox - Photo Album
1977 Silverado K20 Camper Special - Photo Album
1972 C10 Custom Deluxe Highlander - sold
1971 Cheyenne Super Longhorn -sold
1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb.
1970 Chevy C10 SWB "Sprout" -sold
1972 Cheyenne K20 -sold
1969 GMC Shortbox Stepside 4x4 -sold
1972 GMC Jimmy 4x4 -sold
Tomahawk30 is offline
Old 07-15-2011, 01:42 AM   #2495
dukcaln
dukcaln's Avatar
adapters/spacers and new draglite wheels and new dunlope tires... finished undercoating
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 07-15-2011, 05:16 AM   #2496
bellemare_486
bellemare_486's Avatar
Final prep for paint tailgate and hood. Got drivers' door half way there. Tomorrow paint. The next day 5 years and an unknown amount of hours and money will turn an obsession into reality
GENERALM
bellemare_486 is offline
Old 07-16-2011, 08:59 PM   #2497
Bull72
Bull72's Avatar
Painted the firewall and inner fenders. Pressure washed it, scrubbed it and sprayed it all black. My buddy has a paint gun, and he had some extra black paint. I just bought a little paint thinner and taped her up... Not exactly a 100% attention to every little detail here, but I didn't want to pay a shop to do it.
Before, during and after pics ...
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline
Old 07-16-2011, 09:12 PM   #2498
Rob H.
Rob H.'s Avatar
I pulled the cowl panel off getting ready to unbolt the front end. Cut the back bumper off and that later model bumper and push bar off. I removed the front panel from the rusty bed I pulled the other day, it is perfect. I'm gonna have to replace the back half of the frame it's swiss cheese. I did find a donor, just haven't got it yet, price is right trading scrap for scrap! You know what they say one man's junk is another man's treasure!
Rob
48 Willys CJ2A
Rob H. is offline
Old 07-16-2011, 09:20 PM   #2499
bruin_d
bruin_d's Avatar
Cleaned up/painted the tranny. Test fit/adjusted the new Lokar shifter so i don't have to do it when its in. Bolted tranny to motor....its going in tomorrow!!!!!
bruin_d is offline
Old 07-16-2011, 09:52 PM   #2500
wwotr
wwotr's Avatar
Bought a Gas Tank Carpet Kit and a Fiber Board Cover.
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline
Closed Thread
