Old 07-08-2011, 12:15 PM   #1
My Alter Ego
Show me pics of your gauge panel
Looking for pics to get ideas to upgrade my gauge panel. Stock panel with aftermarket gauges, aftermarket panel and gauges, etc. If you have specs and sources that would be very helpful. Thanks in advance
My Alter Ego is offline   Reply With Quote
Old 07-08-2011, 12:25 PM   #2
Ackattack
Ackattack's Avatar
Re: Show me pics of your gauge panel
the large arrows are the turn signal indicators and the generator/oil pressure dummy lights are my check engine light and bright light indicator
Ackattack is offline   Reply With Quote
Old 07-08-2011, 01:25 PM   #3
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
heres mine
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 07-08-2011, 11:20 PM   #4
emil77
What's the gauge to the right of the steering column for? It's to the left of the oil pressure gauge, mine is empty?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 07-08-2011, 11:34 PM   #5
fastom
That's right, it's Copper!!
fastom's Avatar
Mine
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 07-09-2011, 12:42 AM   #6
yuccales
yuccales's Avatar
That was for a vacuum gauge.
yuccales is offline   Reply With Quote
Old 07-09-2011, 01:24 AM   #7
emil77
Thank you!
Thanks,
Emil
1972 Chevy C20
Old 07-09-2011, 01:27 PM   #8
My Alter Ego
Thanks for all of the responses and keep them coming.
Old 07-09-2011, 02:21 PM   #9
Dunenutt
Newbee
Dunenutt's Avatar
Here's mine. Brothers panel, all Autometer gauges.
Dunenutt is offline   Reply With Quote
Old 07-09-2011, 02:52 PM   #10
wwotr
wwotr's Avatar
Here's mine, Billet Panel from "Docs Customs" and all Autometer Gaugers with Green LED Lighting from "Superbrightleds.com".
You can see the LED lighting at night, here at:
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 07-10-2011, 12:39 PM   #11
Fastfun
Fastfun's Avatar
Here is mine
Fastfun is offline   Reply With Quote
Old 07-10-2011, 03:40 PM   #12
capev86
tach and vac gage add on kit from the car and truck shop. only thing i had to add was some fittings and a vac line from the vac gage to the carb.
[IMG][/IMG]
[IMG][/IMG]
capev86 is offline   Reply With Quote
Old 07-10-2011, 04:49 PM   #13
emil77
How did you take your gauge cluster off? I want to remove mine to change the bulbs to LED's.
Thanks,
Emil
1972 Chevy C20
Old 07-10-2011, 05:49 PM   #14
Kidd-7
Kidd-7's Avatar
[IMG][/IMG]
[IMG][/IMG]
Love the simplicity & Old school look of it. How did you get it so clean? got a link to the car & truck shop. Thanks.
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 07-10-2011, 05:57 PM   #15
77chris03
77chris03's Avatar
heres mine thats not in yet. all original gauges i have several left from the several clusters i tore apart..lol for sale and cheap of course.
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 07-10-2011, 07:47 PM   #16
capev86
i can pull every bulb without pulling the cluster. my advice is that you pull the dash pad, especially if you don't have a tilt wheel. i have the 3 on the tree (and hence a rigid column) and it is a real squeeze wiggling it in and out. the top edge of the circuit board is easy to pinch this way!
all you have to do is disconnect the speedo cable (twists off), pull the plug on the passenger side that plugs into the board, remove the screws around the perimeter of the dash panel (on the inner edge of the chrome ring and unscrew the two big screws holding the little piece of sheetmetal that acts as a skirt around the bottom of the steering column. on my truck i now have to unplug the tach sender from the tach and yank off the vacuum hose too (just a push on connection).
yes....that is what i am after with my truck. a base model truck (well it is a C20 custom deluxe). doubt any 3 on the tree trucks came a tach. and nothing below 1-1/2 ton ever got the vac gage but you can add it easy and make it look right since there is a spot in the cluster for it. i am adding just enough to make it user friendly and beef it up for trailer towing (sway bars and all the poly chassis bits from CPP that will work with a stock truck) but it still sports the factory interior and even the stock hub caps!
don't know what you mean? the cluster face is the original faded piece with cracked chrome. i just made sure it was dust free when i put it back together. the kit only reuses the face, gages, and i believe the small back panel that the temp and battery gages attach too. you get a new panel for the oil pressure gage to make it easier to mount the vac gage.
http://www.truckandcarshop.com/
[IMG][/IMG]
Old 07-10-2011, 09:01 PM   #17
96blazr
96blazr's Avatar
I'm keeping it as close to "68 Hot Rod" as possible. Just couldn't resist the white face gauges and Tach though.
1968 SWB.
GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators.
Remember, no matter where you go,
There you are.
Gary
96blazr is offline   Reply With Quote
Old 07-10-2011, 10:57 PM   #18
LockDoc
The Older Generation
LockDoc's Avatar
Here's the cluster in the Green '67 DD...
LockDoc
Leon
Old 07-10-2011, 11:29 PM   #19
Kidd-7
Kidd-7's Avatar
Thanks capev86; it looks clean in the picture, maybe the lens is just faded on my truck's gages.
Old 07-11-2011, 02:43 PM   #20
tdp67
tdp67's Avatar
These look pretty cool
http://www.egauges.com/vdo_grou.asp?Series=67_72_ChevT
tdp67 is offline   Reply With Quote
Old 07-11-2011, 02:44 PM   #21
tdp67
tdp67's Avatar
Here's the ones in the 67, they are in the truck I have for sale listed below.
Old 07-11-2011, 08:02 PM   #22
71gmcburb
71gmcburb's Avatar
here's the clean and simple one I did for my burb
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 07-11-2011, 08:21 PM   #23
swierker
swierker's Avatar
I like the look of this one a lot. How did you do the white around the gauges?
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-11-2011, 08:36 PM   #24
71gmcburb
71gmcburb's Avatar
you disassemble the cluster and there is a metal piece that goes between the lens and gauges. I masked off the turn signals and sprayed that tin gloss white. I reassembled the dash like I said clean and simple here's a link to the pics i took when i did it you will have to scroll down a little ways to see the pics
http://www.cardomain.com/ride/388934...an-1500/page-5
