#101 |
Re: building my first lowered truck
ill check for you tomorrow if i remember. and im assuming they are just passenger car tires. overall tire height is 26"
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob? http://67-72chevytrucks.com/vboard/s...d.php?t=438132 |
#102 |
put the bed on the chevy today. makes me want to finish it some day.
#103 |
cool build, anymore progress? are you up in yucca?
70 c10 long bed 57 chevy 2 door wagon 07 tahoe 96 civic commuter |
#104 | |
quote from c10forum.com so you know where im at
current plan: 2" Z to lay the frame flat and using 2"x4" to do a SFBD. going to put the tubing in the bottom of the frame, cut the top of the stock frame off, and move the body mounts down. question for you guys, i only need roughly 1" of body drop to lay rocker but 2x4 is several inches shorter (height wise) then the stock frame. should i over body drop so i can be another 1" or so into the rocker? give me input and insight on that please. well heres the progress from today: got the front clip and wiring loom off. also sealed up all open lines ![]() got the interior cleaned out, seat out and doors off. ![]() also the bed unbolted, air management out and most of the air line and wiring loom clamps removed. ![]() plan for tomorrow is to get the cab and bed off. if im lucky the motor/tranny out also.
#105 |
progress from today. first i got the cab and bed raised off of the frame. cab fell once and landed on my distributor. ill see at some point if i damaged it.
![]() then i got the motor and tranny pulled. ![]() got the motor on the stand ![]() i have a few questions about my tranny, its a TH350 btw. first, when i pulled it what im assuming was water came out of the lines, any ideas why? then next, where the kick down cable bolts to the tranny, the hole is stripped. how would i fix it? ![]() ![]()
#106 |
picked up a 20' stick of 2"x4" .188 wall to start the SFBD!
#107 |
anyone even following my build on here? lol
well i had the intensions of getting the frame going on the chevy this weekend BUT i drug a hole in my gas tank in the yota. i did pick up a 20' stick of 1/2" X 1/2" tubing for the chevy to use as frame braces to keep it square during surgery. i patched the gas tank with JB weld, then raised it. also put bolts in the upper control arms, lol. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() there's a pic of the chevy, haha ![]()
#108 |
Looks good...keep it going!
Posted via Mobile Device |
#109 |
aww a reply
#110 |
keep at it and it will be their before you know it
#111 |
well i got really lucky and came across a free parts truck. going to take the bed, bumper, tail lights, tail gate, interior parts, door handles, radiator, and much more. going to get started on it tomorrow.
#112 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Just checkin in on the build...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#113 |
Nice build, looks good, and lots of work. Awesome job, can't wait to see it finished.
Scott |
#114 |
dazed and confused
looks great
members met: redbaron69, billsbowtie,nc67 |
#115 |
well ive been lazy about updating this. got the truck down to bare frame and started the SFBD
frame all on its own ![]() ![]() built a frame for the cab but its to flimsy. lol! ![]() then got the frame on my buddies s10 with just us two. it was a b!%@%h! ![]() its new home. yes! that is a garage. im so stoked to be able to work on it regardless of the weather. also have any tools id ever need at my disposal. ![]() got the first side mocked up ![]() then lots of trimming and test fitting ![]() got both sides tacked in by the end of sunday night. ![]() should be working on it 2-3 days a week from now on. probably going to have my buddy build a crossmember after all and maybe arms too. boxing in most of the frame and im tempted to re bag the rear already. time will tell i guess.
#116 |
![]() Join Date: Jul 2011
Is there a reason you ran 2x4 inside
the frame instead of just using like 1/4'' and boxing it? Build is looking great!!
Master welder I've got a degree in metalfusionology
#117 |
more material on the bottom to drag and i was going to make it my air tank originally.
#118 |
Running on empty
[QUOTE=laid_out_70;4783663]anyone even following my build on here? lol
[QUOTE] Lot's of people are following your build, look at the view numbers.......; Great build, you are machine,,,...keep up the great work
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
#119 |
![]() Join Date: Feb 2011
Mate ya not holdin back! good that ya cracking along not doin this before. Keep it up!!
#120 |
Cool just wondering I used my tube chassis on my rock crawler to hold antifreeze, you could set it on fire and not get it to 220.
#121 |
got a couple hours of work in on the frame tonight
first i cut the top portion off and pie cut the frame section in front. ![]() brought the top frame section down to make the frame a consistent slope ![]() close up ![]() ![]() both sides tacked up ![]() heres the next little trick ![]() second side came out cleaner, always works out that way. ![]() bam! ![]()
#122 |
did work today!
welded in these filler pieces first ![]() then these for the front ![]() also welded up the pie cut front portion ![]() then the inside ![]() next i sanded down everything. ![]() ![]() then i welded up the front section of the 2x4" to the stock frame. the bottom portion has about a 1/2" gap and was a mission to weld up. ![]() ![]() ![]() then i started welding the 2x4" to the stock frame, the top portion. i did 3-4" stitch welds alternating from left side to the right frame rail. (some of the decent beads) ![]() ![]() ![]() this is from the first pass ![]() got it all welded up on the top by the end of the day ![]() ![]() and this is my new daily, traded my bagged yota for it. now i have the best of both worlds ![]() ![]() ![]() ![]() ![]() ![]()
#123 |
Nice work on the frame! this truck is a work of art.
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#124 |
Mate!! Ya did a bloody good job on that frame. Im hooked on this thread!! Haha. Makes me want to bag mine.
#125 |
thanks guys, it is scary that this is my first build and ive only been fabbing for about a year now? lol
