Old 07-11-2011, 06:05 PM   #1
66 lwb cs
66 lwb cs's Avatar
Do I need the idler arm?
Hi I'm gathering the parts to do the power steering conversion on my 66 and was wondering do I need the idler arm off the donor truck. Thanks in advance.
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 07-11-2011, 06:19 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Do I need the idler arm?
When I did my 1960, I got rid of all the undersize and expensive original steering linkage and replaced with the parts from the 1975 donor. I used the later idler arm as well so everything matched. I made a template out of manila file folder off the 1975 frame, which positioned the idler arm in exactly the correct location on my 1960 frame. I'm not sure what the 1966 idler looks like, but I'd want the newer components even if it requires a different mounting location.
Old 07-12-2011, 01:30 AM   #3
Captainfab
60-66 Nut
Whenever I have done a disc brake conversion, I use the entire steering linkage from the donor truck. You will need to locate and drill new holes for it, but that can be done using the method markeb01 described. Besides, that makes it easier to remember what parts to get when something needs replaced.
