07-10-2011, 05:06 PM | #1 |
Tips on how to remove body from chassis
I need to remove the body of my burb to work on my chassis, I need to paint the chassis. I dont have a garage, so I am working outside on a concrete slab, what do you guys do to remove it and to support it. Any pictures ideas, thanks
07-11-2011, 10:04 AM | #2 |
Re: Tips on how to remove body from chassis
anyone has done this. How many supports do you need for the body.
Thanks |
07-11-2011, 11:56 AM | #3 |
Restoration Virgin!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-11-2011, 12:25 PM | #4 |
thanks gcburdic, that helps
07-12-2011, 04:30 PM | #5 |
does any one knows what is the weight of the suburban body, without the front clip.
thanks |
07-12-2011, 07:23 PM | #6 |
BlahBlahBlah
It takes this many, and man is it heavy. I built a cart for mine. But if you are just going to set it down try not to set it too low on whatever kind of platform you come up with. It will make it easier when you go to pick it up. Hopefully your friends will answer the phone when its time to put it back on the chassis =)
