Closed Thread
Old 07-12-2011, 02:31 PM   #3401
Clyde65
Clyde65's Avatar
Re: What did you do to your truck today?
rockdriller, how did you do the repair? did you just piece it or what?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 07-12-2011, 03:12 PM   #3402
A.T. RockDriller
A.T. RockDriller's Avatar
Clyde...
Someone had over-sized the square in height by 1/2" overall and drilled another set of tuner knob holes inboard of the oe's....
I made a plate with the correct dimension square and long enough to cover the new holes....short enough to miss the original ones.
I placed the plate inside the dash..(from the back) and welded it in place.
I patched it "overlap" style and leveled off my welds with a die-grinder leaving a bit of bondo work to do...but over-all turned out great.
The only actual "sculpting" that I had to do was below the repair where the contour changes. The rest was very close.
Maybe I should have done a "flush" graft, but I'm probably not that skilled.
Anyway....thanks for the props.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline
Old 07-13-2011, 06:24 AM   #3403
glos55
glos55's Avatar
Installed new grille, headlights, bezels, parking light lenses, bezels, and painted white accent band around grille.
glos55 is offline
Old 07-13-2011, 01:00 PM   #3404
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
All I did was order more parts and pay for the last ones i just got.....planted my first money tree no sign of any growth as of yet.
glos55
Really like the rims and caps your running.....nice fit
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline
Old 07-13-2011, 01:15 PM   #3405
daverod
SSN 706
daverod's Avatar
Wonder what happened to lakeroadster. I wanted to see his paint job. Was he a bad boy?
daverod is offline
Old 07-13-2011, 01:28 PM   #3406
glos55
glos55's Avatar
Originally Posted by daverod View Post
Wonder what happened to lakeroadster. I was hopping to see his paint job. Was he a bad boy?
Yeah Lake, what gives?
glos55 is offline
Old 07-13-2011, 02:46 PM   #3407
T Smith
T Smith's Avatar
I replaced all my lock cylinders with a set keyed alike from Classic Parts, now I need only carry one key and my glove compartment locks to boot, nice!
T Smith is offline
Old 07-13-2011, 04:48 PM   #3408
kieth
kieth's Avatar
Almost finished the bed wood today, learned a lot...........loose is better keep a few 1/4 X 2 carriage bolts around to suck things into submission, take your time I am really impatient. Kieth
http://kieth.smugmug.com/Trucks/66-G...407491_vcsTLN8
kieth is offline
Old 07-13-2011, 07:15 PM   #3409
wutnxt
The new engine mounts are all in and that puts it back another 6" and down another 2"......ready for the new engine thats almost ready to go . New cross member is in and the tranny is mocked up. Now we are cooking
wutnxt is offline
Old 07-14-2011, 09:54 PM   #3410
dean jendro
Old and crusty
dean jendro's Avatar
Got my new radiator today from Entropy Radiator. Very nice!! Maybe this weekend I can mock up the front under hood sheetmetal and run the trans lines.
dean jendro is offline
Old 07-14-2011, 10:45 PM   #3411
Turkey
Turkey's Avatar
started slickin off the sides
Turkey is offline
Old 07-15-2011, 07:02 AM   #3412
glos55
glos55's Avatar
Unhappy Re: What did you do to your truck today?
glos55
Thanks! I have the stock wheels that have been blasted and painted black base/clear, I was going to run them with a thin white wall but everyone seems to like the vette rallys with the spinner caps. p.s. my money tree isn't growing either!
glos55 is offline
Old 07-15-2011, 10:55 PM   #3413
samuellg1977
samuellg1977's Avatar
I took my truck down to Sango, TN with my daughter riding shotgun. We hit a rough patch on a bridge and the rearend hopped around a bit. My daughter looks at me from the passenger seat and says: "Slow down, Dad... You know you don't have AIRBAGS!!!" I laughed the rest of the way home.
samuellg1977 is offline
Old 07-15-2011, 11:33 PM   #3414
wutnxt
Got my wheels back from being polished and my new tires mounted......it was a good day....
wutnxt is offline
Old 07-16-2011, 03:23 AM   #3415
pdxhall
pdxhall's Avatar
I finished removing the suspension and rear end from the frame and did some more cleaning up of the frame rails....getting closer to paint time for the rear frame rails.
pdxhall is offline
Old 07-16-2011, 03:47 AM   #3416
iehotrod
iehotrod's Avatar
That cab looks super clean in the picture. Is that still the Og paint?
iehotrod is offline
Old 07-16-2011, 03:05 PM   #3417
markeb01
Senior Enthusiast
markeb01's Avatar
Pulled my battery tray, stripped off the battery corrosion and painted it with epoxy primer followed by battery terminal protective coating. Also installed an absorbent battery mat in the bottom of the tray. We’ll see if that makes any difference. I’m sure tired of needing to do it over every few months.
markeb01 is offline
Old 07-16-2011, 03:52 PM   #3418
pdxhall
pdxhall's Avatar
hotrod, yeah it's all original. 133,000 mile 2nd owner truck with very little rust. picked it up for 650 bucks.
pdxhall is offline
Old 07-16-2011, 05:24 PM   #3419
iehotrod
iehotrod's Avatar
Thats a deal!
iehotrod is offline
Old 07-16-2011, 08:56 PM   #3420
awbrown
Drove mine around town in search of the perfect yard sale dresser .. finally found one at the community thrift store .......
awbrown is offline
Old 07-16-2011, 09:27 PM   #3421
64shortbox
64shortbox's Avatar
Smile Re: What did you do to your truck today?
I scored BIG TIME!! Nosing around the local self serve wrecking yard and found a very nice rust free drivers door for my 64 truck. There's not even a speaker hole cut in it. Got it out the gate for $51.53 including tax and a $3.00 core charge. Unfortunately the passenger door was smashed in at the door handle or I would have bought it too.
64shortbox is offline
Old 07-16-2011, 11:10 PM   #3422
nachodog2
Hell yeah!!!
nachodog2's Avatar
Finally got my drive shaft shortened, and installed it behind my t5. What a difference. It runs real good.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 07-17-2011, 01:15 AM   #3423
markeb01
Senior Enthusiast
markeb01's Avatar
Great score! Welcome to the forum.
markeb01 is offline
Old 07-17-2011, 02:26 AM   #3424
Andyboy
Andyboy's Avatar
I tried to adjust the carb on my v6 305 but nothing it still bogs down when I press the gas pedal and the radiator was leaking from the top where the little hose goes but It was just idling. Sometimes I just want to sell it and have a ride that I can drive.
Andyboy is offline
Old 07-17-2011, 02:49 AM   #3425
A.T. RockDriller
Andyboy....The OE Stromburg carb on your 305 is affectionately known as the "Petroleum Brake" for a reason.
You might try putting a Holley 500 on it and go from there.
She won't be go like a funny car, but you'll sure enjoy the difference.
Don't sell her on account of the OE carb.....That was just a mean trick from the engineers at GMC..........At least that's what I'm thinkin'.
Les Hunter
Closed Thread
