Old 07-11-2011, 01:16 AM   #1
71sliverbullet
Needs help badly
Ok i have just started on my project truck of my dreams. i have 71 chevy c10 4x4 with a 350 and what i call a four speed but i have problems and questions and will take any and all help i can get. i have switched the axles to 3/4 drive train and moved spring perches and all that jaz but i have to put and np205 transfer case behind the manuel but dont know which one i need or anything along those lines. and i also have to put longer brake lines on it since i have lifted it 6 inches but with the axles being newer than the truck i dont know which lines will work. any tips please let me know. thanks for everything
71sliverbullet is offline   Reply With Quote
Old 07-12-2011, 09:38 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Needs help badly
ttt anybody?
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-12-2011, 08:59 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
You might try having a mod move this to 4x4 Tech & Off Roading Forum. You might have better luck there. Just a thought.
LockDoc
Leon
Old 07-13-2011, 07:26 PM   #4
Todersauce
I dont know much about youre T case but I have learned a lot about brake lines. What are you running all disk or all drum? fron disk or rear drum?
WFO www.wfoconcepts.com has quite a few brake parts like flex lines and fittings I ordered a bracket and rear line from them and i got my hard line from napa.
Todersauce is offline   Reply With Quote
Old 07-13-2011, 08:14 PM   #5
b454rat
What tranny and t-case are in the truck now?? If you have a 4wd 4-speed, it should have the 205 behind it already. But there are only two types for a 4-speed, one with 10 spline that uses a spud shaft, and the late 80s that slips into the t-case that is 32.
Brake lines are simple, get them for the year of the axles.
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
3speed, 71 chevy c10, c10, chevy truck, np205
