Old 07-09-2011, 05:40 PM   #1
cmabolt
cmabolt's Avatar
ho52 to dana 60 yoke u-joint??
hi all, Just picked up a dana 60 out of a 71 gmc 3/4 4x4. I am swapping it into my 72 3/4 4x4 which currently has an ho52. the perch width on the dana 60 is 40.5 and both shocks are facing forward so from what i have read this is a direct bolt in. i am not sure about the yoke though. Will the stock yoke from the dana 60 work with current u-joint or do i need to modify the dana 60??
thanks in advance for any help.
Also, I have the backing plates off the original axle for drum brakes if anybody is interested? They need to be blasted and painted and should be good to go. I hear their really hard to find.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636
Easier to beg forgiveness than ask permission!
cmabolt is offline   Reply With Quote
Old 07-12-2011, 03:47 PM   #2
kwmech
Re: ho52 to dana 60 yoke u-joint??
U-joint should be the same...1350 series
Old 07-12-2011, 04:09 PM   #3
cmabolt
cmabolt's Avatar
Hey thanks for the info. I am guessing that the yoke should be ok as well???
Chris
Old 07-13-2011, 10:21 PM   #4
kwmech
Chris
As long as the u-joint fits snug and does not move side to side when installed
