Old 01-03-2011, 10:12 AM   #1
dznucks
dznucks's Avatar
Classic Parts LED tail lights
I recieved a pair of LED tail lights as a x-mas gift. they are from Classic Parts.
I thought i remember reading that you needed a special flasher (or something) for using LED's in tail lights or parking lights. The catalog and the instructions make no mention of using or needing anything extra in the wiring to make them work properly. Can anyone enlighten me?
thanks
dznucks is offline   Reply With Quote
Old 01-03-2011, 10:34 AM   #2
mr48chev
mr48chev's Avatar
Re: Classic Parts LED tail lights
Quite often the LED bulbs don't draw enough amps to trigger a standard flasher. That is the reason for changing the flasher. The standard flasher may see it as a bulb being burned out and not work.
Old 01-03-2011, 10:45 AM   #3
dznucks
dznucks's Avatar
What flasher do i need?
Old 01-03-2011, 12:08 PM   #4
Clyde65
Clyde65's Avatar
I have heard you can put a "load resistor" in line with the LED light, but seems a flasher would be easier and quickly replaceable. I would look on some of the LED light web sites and see what is recommended. They might even sell you one.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-03-2011, 12:45 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Show a picture of the LED's, I have the ones from LMC with it being a whole assy and I dont need a special flasher. (So far)
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 01-03-2011, 01:28 PM   #6
ls1nova71
ls1nova71's Avatar
You don't need a special flasher if you're still running the original 1157 bulbs in the front turn signals, they will put enough load for the old style of flasher to work. If you're also running LEDs in the front, then you would need an electronic flasher.
ls1nova71 is offline   Reply With Quote
Old 01-03-2011, 01:33 PM   #7
dougminton
dougminton's Avatar
When I put my L.E.D.s in it would blink, But it was very slow.
An electronic flasher from the local parts house fixed it for about 8 bucks.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 01-03-2011, 03:51 PM   #8
dznucks
dznucks's Avatar
I'll get a pic later.
I installed them and took it for a drive. i did notice the lights flashed slower. several times i noticed the drivers side turn signal indicator go green even though i wasnt using the blinker. It would go out and then come back on, only to go back out.
Does this mean i need a special flasher?
Why would it make the turn signal indicator light up like a bulb was blown?
Old 01-04-2011, 05:02 AM   #9
shiner2001
shiner2001's Avatar
When I added LED rears, they worked fine with the flasher that was already in there. This was also true on my Jeep when I added the trailer-style LEDs in the rear corner guards. I think the combination of the other lights on the circuit is sometimes enough to show the flasher the load wants to see, but often time the flasher will indeed have to be replaced, maybe a case by case type thing. I would imagine that long lengths of old wiring (to the tail lights as well to the front) also contribute to the necessary load. The ones I added to my 72 were the ones that just plug into the original light socket, no wiring required. I'd say toss 'em in and see what happens, maybe it will be good to go with your stock flasher.
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 07-15-2011, 01:58 PM   #10
hjewell2
hjewell2's Avatar
Are yours visible during the mid day. stop and turn light???
hjewell2 is offline   Reply With Quote
Old 07-15-2011, 05:15 PM   #11
71chevydude
i recently got a set from ECE and it called for a electronic flasher in order for it to work right..cant wait to try them out
71chevydude is offline   Reply With Quote
