door handles ? 72
so my driver side door handle is missing the button to push in to open the door, so I have to muse my finger and insert it into open hole and push the mechanism inside to open the door. My question is do I need to replace entire door handle, and ir so how hard, or can I just get another botton and insert it...
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Re: door handles ? 72
You will need to replace the handle pull the inside door panel and you will see the 2 bolts that hold it to the door.
Fuzzy |
thank you........... what years will interchange
1967-72 truck outside door handles are the same, right and left side are different though. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
68-72 are the same. If you try to use an used 67 handle you will go crazy trying to get it to work and it will not.
72 Cheyenne Super 80 Silverado Blazer 2wd |
you can go to a wrecking yard and find one i suppose if you dont want to change the whole thing but then again you still have to remove the door pantel to replace the button.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
I have even had the brand new drivers side handle loose the button inside the door after just a month. New doesn't necessary mean quality with door handles.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
