Old 07-16-2011, 03:20 PM   #1
frankyjoet
Red face engine won't shut off
I have this acutron remote starter to start the engine. The engine starts but won't stop. I even disconnected the cables from the battery. There is no other source of elec power, not even a fuse box. I had to put a rag over the carb to stop engine. I am troubleshooting this newly restored 350 while i have this hookup. Any answers. Thanks in advance. 73 oldie
frankyjoet is offline   Reply With Quote
Old 07-16-2011, 04:07 PM   #2
76stepsidechevy
Re: engine won't shut off
You're probably backfeeding the distributor somehow. as long as that has power the engine will run. Either the remote starter is wired wrong or you might need to add a diode somewhere.
76stepsidechevy is offline   Reply With Quote
Old 07-16-2011, 04:53 PM   #3
juiceman650
juiceman650's Avatar
Alright, this is pretty obvious but I'm not trying to offend you because its happened to me before. Are you starting it with the remote and trying to shut it off with the key? Or are you starting it with the remote and trying to shut off with the remote? I had a Mustang with remote start once and had to hold the button down for like a minute to shut it off.
juiceman650 is offline   Reply With Quote
Old 07-16-2011, 05:07 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
disconecting the battery the engine will run on the alternator, its a good way of checking if your alt works on an old vehicle. try the doide idea
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-16-2011, 06:14 PM   #5
frankyjoet
Red face Re: engine won't shut off
Hi juiceman, The remote is an " acutron." One alligator clip goes to the sol post and the other goes to the pos post on "batt." Once the engine starts i immediately remove the pos alig clip. On the batt post on the starter i have the pos cable from batt, and 2 wires coming from the alt. All on the same post. One wire comes from the hot post on the alt and the other comes from the 2 wire plug. This could be the problem. The "ezwiring" manual did mention a diode, but where does it go and where do you get it from. The 2 wires coming from the alt, the hot post and plug are soldered together to a " fusible wire." The wire coming from the "dist" batt hookup goes to the pos cable, a constant 12v. That' s all the wires. I hope this helps. Thanks frankyjoe w/73oldie
Old 07-16-2011, 06:37 PM   #6
83highsierra
83highsierra's Avatar
i have one on all my cars does it have the safety brake switch on it cause once you engage the remote start it runs on its own brain so to speak. it will disengage once brake is depressed or you hold the remote start button on remote
83highsierra is offline   Reply With Quote
Old 07-16-2011, 06:45 PM   #7
frankyjoet
Hi 83hisierra, No i have a foot park brake- no idiot lights- but i will try the remote starter button. Thanks 73oldie
Old 07-16-2011, 06:54 PM   #8
83highsierra
im sure the system came with a "brake switch" if so you could just rig up a button switch under dash or somewhere just an idea
Old 07-16-2011, 07:35 PM   #9
frankyjoet
If you are referring to the "brake switch combo third lite yes i have but it is not hooked up as i am just beginning to rewire the truck. thanks
Old 07-16-2011, 07:37 PM   #10
83highsierra
sorry i was reffering to the remote starter kit
Old 07-16-2011, 07:44 PM   #11
frankyjoet
the remote starter is basically a gun and 2 alligator clip wires. thanks
Old 07-16-2011, 07:49 PM   #12
83highsierra
wow sorry i was talking about about a remote starter system was way off disregard all i said
Old 07-16-2011, 08:04 PM   #13
notyo_cheez
Bad solenoid, perhaps?
notyo_cheez is offline   Reply With Quote
